Dang: injector connectors
Old Aug 17, 2004 | 11:32 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Default Dang: injector connectors
While taking the injector harness off on the driver`s side, ( I`m replacing the injectors ), I broke the plastic clips off three of the electrical connectors that go to each injector. Is there a better way of holding these on when I install the new injectors, without resorting to wire ties?. I don`t know if you can buy just the connectors.
Ken
Old Aug 18, 2004 | 12:24 AM
Hooked on Vettes's Avatar
Hooked on Vettes
http://www.ecklers.com
Input in the keyword/description box
Fuel injector connector
They sell just the connector or the connector with pig tail.
Your local Napa store should carry the connector but from my experience their prices are high.
I just purchased a knock sensor plug/connector and it was $14.00. Ecklers sells the plug for $4.00 but the quality wasn't as good as Napa's.
Old Aug 18, 2004 | 06:43 AM
kenv's Avatar
kenv
St. Jude Donor '10
; Thanks
Ken
To Dang: injector connectors
