engine problem
Old Aug 24, 2004 | 03:59 PM
dm1948's Avatar
dm1948
Default engine problem
have a 89 just had it tuned up runs great, but every couple of days
it dies at low speed but will start again and run great again can not
notice any pattern. HELP!!!!!!!!!!!!!!!!!!!
Old Aug 24, 2004 | 06:12 PM
JAKE's Avatar
JAKE
I suspect the IAC and the TB port where it screws in need cleaning. Probably a carbon buildup.
Jake
Old Aug 25, 2004 | 08:48 AM
dm1948's Avatar
dm1948
Jake
not sure what tour talking about, is this something i can do if so
can you give me some direction or should i have my mechanic do?
thanks
Old Aug 25, 2004 | 09:50 AM
rick lambert's Avatar
rick lambert
If you're mechanically inclined-yes. It's just a matter of removing the TB-using carb cleaner and nothing stronger than a tooth brush to clean it. The IAC is attached to the TB, and it too should be cleaned.Hope you have some kind of manual. BUT-I'm wondering when was the last time the fuel filter was changed?
Old Aug 25, 2004 | 02:53 PM
dm1948's Avatar
dm1948
thanks for all the info, thats what i thought it was the fuel filter so
i had them change it for me, but still had the problem
thanks again
To engine problem
