Fuel Pressure?
Old Aug 24, 2004 | 11:11 PM
toyvet1's Avatar
toyvet1
Default Fuel Pressure?
Just installed a new AC241 fuel pump in my car. Key on engine off and I only can get 41lbs . Start the car and pressure dropps to 32lbs. When I pinch the return line there is no change n pressure. Is this normalk pressures. They sem low to me.
Car is a C3 with a L89 new fuel regulator, filter.
Old Aug 25, 2004 | 06:39 AM
toyvet1's Avatar
toyvet1
ttt
Old Aug 25, 2004 | 06:54 AM
comp's Avatar
comp
it does to me to , but someone should chime in
Old Aug 25, 2004 | 08:38 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Those are similar numbers to when I had a stock reg. Ran fine.
Old Aug 25, 2004 | 10:03 AM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
Mine is a little higher, but those are good numbers.
To Fuel Pressure?
