D36 Question
Old Aug 31, 2004 | 05:10 PM
aklim's Avatar
aklim
Default D36 Question
Does anyone know how much power a D36 mated to a 700R4 with a 3600 stall can take? TIA
Old Aug 31, 2004 | 06:05 PM
smallblock's Avatar
smallblock
If your running street tires you will be ok. If you run drag radials or slicks you could run into trouble quick especially with a 3600 rpm converter. I make 305 rwhp and run a vigilante 3100 converter with a D36 3.07 rear. It's been ok so far.
Old Aug 31, 2004 | 06:08 PM
aklim's Avatar
aklim
I am planning to take it up to 3.73 rear Gears. TIA
Old Aug 31, 2004 | 09:21 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
With that combination of gear and converter, you'll probably bust it sooner or later.
Old Aug 31, 2004 | 10:36 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
How much torque do you plan on making? With that kind of stall and a modded L98 I wouldn't expect them to last very long. Here's my D36 w/3:54s after jumping on it with my 396 and a 3500 convertor. I still haven't dynoed it, but I wouldn't be suprised if it hit 500 lb/ft.
Old Aug 31, 2004 | 11:06 PM
vader86's Avatar
vader86
There is no concrete limit to how much torque a D36, or your transmission, can handle.
Once you get over 400-425, both are in the gray area. It'll last 50mi, or maybe 50,000mi.
That said, if you keep the tires as street and no slicks, you probably wont need to be worrying about buying a D44 anytime soon. DR's will make it hit or miss, it'll go when it wants to.
Old Sep 1, 2004 | 06:07 PM
aklim's Avatar
aklim
When I had the engine and tranny on the Firebird it dynoed at 411 HP at the wheels.
I have 3.07s in my D36 and I want to know if I should invest in 3.73s for the D36 or get a D44 and then go 3.73.
Old Sep 1, 2004 | 06:41 PM
vader86's Avatar
vader86
You would really be better off getting the D44, you'll probably never have to worry about it for another 100K.
Old Sep 1, 2004 | 07:55 PM
TA's Avatar
TA
I'd definitly put the money towards a D44. After you blow up your D36 you'll end up going to a D44 anyway.
Old Sep 1, 2004 | 09:11 PM
smallblock's Avatar
smallblock
I would definitely go with a D44 .The 3.73 ring gear has no where near enough meat with that many teeth!! If you stayed with 3.07's I think you'd get some mileage out of them..
Old Sep 2, 2004 | 02:54 AM
aklim's Avatar
aklim
So then the consensus is to keep the 3.07s till I have the funds to do a 3.73 in a D44, right?
What are the parts needed?
To D36 Question
