aftermarket tach
Old Aug 31, 2004 | 06:37 PM
1990dtgL98squared's Avatar
1990dtgL98squared
Default aftermarket tach
Well, my search button disappeared? Anyone else missing the search feature?
Anyways, the tach in my 1990 is off about 2 grand at WOT, it read 6000 RPMS when the engine is really turning 4100 RPMS. So I want to buy a new aftermarket tach instead of trying to fix my stock one. But I have 2 questions:
1.) Do I use the wire coming from the distributor to wire in the new tach? If so, will that disable the stock tach?
2.) If I run the wire right from the distributor, would that screw up the car's computer because it would no longer know what speed the motor is running at? If so, how can I disable the stock tach and have the computer read off the new tach. (I must have some rev limiter, as everytime the tach hits 6k, the fuel pump shuts off just enough that I can't rev past that. It has the stock chip though. But I figure I could solve it if I could have the aftermarket tach read right, even though the computer reads the engine speed before the signal is transferred to the tach (is that how it works?))
Old Aug 31, 2004 | 07:27 PM
1990dtgL98squared
Sorry about the double post.
Old Sep 1, 2004 | 04:38 PM
1990dtgL98squared
Anyone?
ANY ideas would help me right about now.
Old Sep 1, 2004 | 05:59 PM
LD85's Avatar
LD85
ttt
To aftermarket tach
