dex-cool rusty colored sludge
Old Sep 5, 2004 | 01:46 PM
dallasredvette's Avatar
dallasredvette
Default dex-cool rusty colored sludge
I made it home last night with my coolant light on and the check gauges light on. I started and stopped and let it cool like 6times and made it home. I noticed that there was that rusty colored sludge in the recovery bottle. Please help. I am having it towed to a good GMAC dealer here in dallas and getting a flush, but has anyone had the same prob. and if so, is it a costly problem. And, Should I switch to normal 'regular' anti-freeze. any help would be greatly appreciated!!!
Old Sep 5, 2004 | 02:26 PM
Timmy!'s Avatar
Timmy!
I had that problem and then did a good flush and it was fine. Then it came back - no idea what causes it.
Old Sep 5, 2004 | 02:51 PM
wildman378's Avatar
wildman378
Hey just wondering...did your 95 come from the factory with the orange dexcool or the green stuff?
my 95 has the green and was just curious.
Old Sep 5, 2004 | 04:11 PM
dallasredvette
my '96 did come with the orange(at least at some point) coolant. heard some bad things about this type.
Old Sep 5, 2004 | 05:35 PM
jabez's Avatar
jabez
One or the other would be fine.
I wouldn't mix the two types of coolant.
Old Sep 5, 2004 | 05:49 PM
jfb's Avatar
jfb
There is a class action suite underfoot, http://www.girardgibbs.com/dexcool.html
GM and Chevron will likely be sued for the engine damage from Dexcool usage. Probably your GM dealer will do the flush and refuse to put anything other than Dexcool back in your cooling system. My recommendation is to have it flushed and put Prestone green stuff in your cooling system. There are many many customers with complaints even worse than yours about Dexcool sludging up and rusting their cooling systems.
Old Sep 5, 2004 | 05:54 PM
CFI-EFI's Avatar
CFI-EFI
Just make sure you do a VERY thorough flush, including pulling the block drain plugs. There is more danger in mixing the two types of antifreeze, than using the wrong one. Part of your current problem may have come from mixing. Either by a former owner, or by unaware service personnel, you hired. If you drain, flush, and renew the coolant every two years, everything it comes in contact will have a much longer life.
RACE ON!!!
Old Sep 5, 2004 | 08:22 PM
Timmy!'s Avatar
Timmy!
My '95 came with the orange stuff - or at least that's what was in there when I bought it 5 years ago.
Old Sep 5, 2004 | 08:35 PM
MYCoupe's Avatar
MYCoupe
I believe 95 was the first year that they used the Dex-Cool. My 94 came with the green stuff. I did a flush and decided to stay with the green stuff. Used the Prestone premix that uses distilled water.
Old Sep 5, 2004 | 08:41 PM
silver & red CE's Avatar
silver & red CE
Maybe it's the dreaded clay pellets. I never use those with Dexcool. A good cooling system doesn't need 'em. My dealer replaced my radiator, used the pellets and turned my coolant into sludge. Took a few full flushes to drive out all traces of the clay. Now it's clean as new after two years.
Eric
Old Sep 5, 2004 | 08:53 PM
comp's Avatar
comp
RACE ON!!!
He's got it dead on
Old Sep 6, 2004 | 12:15 AM
88vettelover's Avatar
88vettelover
Originally Posted by comp
He's got it dead on
He does! I wouldn't even try switching over to the green antifreeze because it will be nearly impossible to evacuate the entire system of the DexCool. Sounds like someone mixed the two in your system, which leads to just plain nasty results.
I've seen it done many of times, and it turns into almost like mud. Brown gooey and very nasty. Just have a thorough flush performed and replace with Dex-Cool.
Somewhere I read that the Dex-Cool was supposed to be easier on aluminum parts than the regular anti-freeze. I've only seen bad results with DexCool and I'm thankful my baby doesn't have it. Best of luck with your car.
Old Sep 6, 2004 | 12:21 AM
wildman378's Avatar
wildman378
Ok from what Ik now some 95's have the green and some have the dexcool. Late ones have the dexcool and mine was built in 05/95 so mine is a mid one so what month was yours made? Just look on your door jam.
just wanting to see about when they started using the dex.
Old Sep 6, 2004 | 01:31 AM
kwd1's Avatar
kwd1
I wouldn't have a dealer do the flush. There's no telling what they will put in it. I'll bet they don't use distilled water either.
It's a several hour job. Open radiator surge tank, radiator drain ****, and take out both knock sensors (they are on the bottom of the block in the middle). Flush with distilled water when everything is open. You can also blow some more coolant out by putting a shopvac blower to the surge tank. Close radiator and block, Fill up with distilled, warm engine up, run heater. Let cool, drain again and fill with 50/50 ditilled/dexcool.
Old Sep 6, 2004 | 03:06 AM
dallasredvette
Default another thing
I forgot to mention that the recovery tank was leaking coolant just as fast as I put it in. So I figure, (I havent' checked, cuz I've been gone all day) that there is a hole or something under the tank. Also, could i go to a good qwick lube or one of those and get it flushed, and then replace the tank? where would I buy the dex-cool?
Old Sep 6, 2004 | 06:41 AM
JTHVETTE's Avatar
JTHVETTE
Default DexCool?
After working on several GM vehicles that had DexCool in them, I would highly recomend changing to the "green" antifreeze. This has shown to be a problem with the Vortec engines dealing with the intake manifold gaskets (they are plastic & rubber). A good flush is a must!
Old Sep 6, 2004 | 09:04 AM
larryfs's Avatar
larryfs
the key issue is MAINTENANCE. if you maintain your cars, they won't develope sludge.
the 5 year dex claim is extreme, but my 96 was never maintained when I brought it in 2001. It was fine, but I flushed it anyway.
To dex-cool rusty colored sludge
Old Sep 6, 2004 | 10:20 AM
silver84's Avatar
silver84
avoid Dexcool.
use green stuff
Old Sep 6, 2004 | 10:40 AM
iceman_t1's Avatar
iceman_t1
I flushed my system back in Feb while changing the water pump. There was green in it that I know was fresh from last Sept. I put green back in and I have rusty sludge in the overflow reservoir. Looks like I will be flushing it again soon.
Old Sep 6, 2004 | 10:53 PM
mvmechanic's Avatar
mvmechanic
As previously mentioned, the key is Regular Maintenance. Distilled water helps a bunch, too.
