Code 32
Old Sep 9, 2004 | 09:17 PM
89vert's Avatar
89vert
Default Code 32
I have been getting an SES light lately after driving for about 40 miles. I pulled the code and I am getting a code 32. Where do you guys suggest I start looking? Thanks in advance. Tim
Old Sep 9, 2004 | 09:54 PM
snakeyes's Avatar
snakeyes
Default let me see if I can help
Your getting an EGR code that much I can say.Maybe try cleaning the EGR valve? Not really that much to the system EGR and tube
Snakeyes
Old Sep 9, 2004 | 09:58 PM
vader86's Avatar
vader86
EGR solenoid/switch first, then likely to be a clogged pipe if that doesnt fix it.
Old Sep 9, 2004 | 09:59 PM
89vert's Avatar
89vert
Snakeyes
I did a search in the archives. I found 1 post that said if it triggered a code it was an electrical problem. It seems to me that I have read in the past that it is common for the EGR temp switch to trigger a code 32. But I am not sure how to test it. Thanks for the response. Tim
Old Sep 9, 2004 | 10:00 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Oops
Old Sep 9, 2004 | 10:02 PM
89vert's Avatar
89vert
Thanks vader86. I have a test procedure for the EGR solenoid/switch. Maybe you have heard of the temp switch causing the code. Whats your thoughts. Thanks Tim
Old Sep 9, 2004 | 10:05 PM
AGENT 86's Avatar
AGENT 86
http://members.shaw.ca/corvette86/Code%2032.pdf
Old Sep 9, 2004 | 10:22 PM
89vert's Avatar
89vert
Originally Posted by AGENT 86
You da man AGENT86. I will go thru the flow chart and let you guys know what I come up with. Thanks for the responses. This place rocks.
Old Sep 9, 2004 | 11:45 PM
SunCr's Avatar
SunCr
Check the vacuum line to the solenoid which is bolted to the thermostat housing. Note that it tees and runs to the canister. Sometimes, it just pulls apart. If the solenoid can't provide vacuum to the EGR, you'll get the code 32.
Old Sep 10, 2004 | 07:12 AM
rick lambert's Avatar
rick lambert
Replacing the EGR switch cured my code 32. It's inexpensive-but plugs in down and behind the distributor. Save some time and just splice the new switch into the old switch line.
Old Sep 10, 2004 | 08:23 AM
TALMADGE's Avatar
TALMADGE
To Code 32
