PCV and breathers question
Old Sep 9, 2004 | 11:52 PM
NUckINg FuTS's Avatar
NUckINg FuTS
Default PCV and breathers question
Would there be a problem with using a breather on the driver side valve cover only? I have a 400 sbc with a modded LT-1 intake to work on a non lt1 block (lt1intake.com). If you are fimiliar with LT-1 pcv system then you know the pcv valve mounts in the intake itself not on the driver side valve cover. The valve covers I want to buy (like most other covers) have holes on the driver side and pass side for PCV provision. I am ok with the pass side valve cover but I am left with a hole in the drivers side cover. Can I just place a breather in the hole or will that cause a vacuum leak detectable by the MAF???
Old Sep 10, 2004 | 02:26 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I'm not familiar with the lt1 setup... but a pcv vent line should never be open to atmosphere on a MAF car. The pcv system needs a metered air source to suck from. If that source is closed off, you'll suck oil into it, if that source is topped with a breather, you have a vacuum leak.
Old Sep 10, 2004 | 08:49 AM
comp's Avatar
comp
sounds correct to me...
Old Sep 10, 2004 | 08:58 AM
HeeHaw89's Avatar
HeeHaw89
So if there are no breathers, you will suck oil? If the pcv is hooked up to the intake, is that a "metered" source?
Old Sep 10, 2004 | 10:48 AM
CentralCoaster
No, the source air should be ahead of the throttle body, behind the maf. If the source air was at vacuum pressure, the pcv wouldn't be able to pull from it, since it's hooked up vacuum also.
Old Sep 10, 2004 | 11:13 AM
Wheelman's Avatar
Wheelman
Funny you post this now as some shmuck at the autoparts store the other day was trying to tell me that I would add hp if I replaced my pcv system with a breather Rule no. 1 don't listen to those people
Old Sep 10, 2004 | 01:47 PM
Ramanstud's Avatar
Ramanstud
Well you can use a breather- just be sure to plug any holes on the throttle body or intake (L98 style) to prevent a vacuum leak. I have *two* open-air style breathers - one on each valve cover - with no vacuum leaks and a normal vacuum manifold pressure. The valve covers can be open-air because it's venting crankcase gasses/pressure from blow-by and not directly connected to manifold vacuum UNLESS the PCV piping is running back into the intake manifold.
In other words, put on a breather- just make sure any holes or random tubing running into the intake or throttle body is plugged up.
Old Sep 10, 2004 | 08:34 PM
CentralCoaster
Yeah, that'll work. It would no longer be a "positive crankcase ventilation" system anymore, but just a crankcase vent... 'Positive' comes from the fact that you're using the manifold vacuum to induce flow... rather than just leaving the crankcase open to atmosphere, as is done on the pre-smog cars.
This is a case where an emissions item increases performance... since pulling a slight vacuum on the crankcase helps seat the rings better. I think it has to do with reducing ring float, but I'm not sure on the details.
Old Sep 10, 2004 | 10:30 PM
6spd's Avatar
6spd
i also have a question about this i have a 91 L98 and i put aftermarket valve covers, i have a pvc on the drivers side and a breather. the passanger side has one breather is this okay??
Old Sep 14, 2004 | 01:59 AM
CentralCoaster
No, it makes a vacuum leak, and harder for the ecm to control idle and a/f ratio.
Either run your original vent tube to the metered air in the TB, or put breathers on both sides and remove the pcv all together.
Also, the fuel cannister purge lines tie into the pcv on the L98, and those work to relieve tank pressure. If you remove this system, plug the vent lines and buy a vented gas cap You'll have nasty gas fumes under your hood otherwise.
Old Sep 14, 2004 | 09:38 AM
JAKE's Avatar
JAKE
No, don't run a PCV and a breather at the same time. It's an "either/or " situation.
If you want to continue using the PCV setup, just buy a rubber grommet plug for the driver's side hole.
Jake
Old Sep 14, 2004 | 10:56 AM
CFI-EFI's Avatar
CFI-EFI
This is true, but even back in the "good ol' days" before PCV systems, the air entered the crankcase through the the oil filler cap sticking straight up out of the front of the intake manifold, AND exited from the "road draft tube" attached to the rear of the block next to the distributor. The "road draft tube" ran down behind the engine and had a 45* cut on the end. The idea was, for the air passing under the car to "draw out" the blow by gasses, through the tube. So even back in the '50's they were promoting circulation rather than JUST venting, to relieve the pressure.
RACE ON!!!
Old Sep 14, 2004 | 01:28 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
On the LT1, does the PCV valve simply screw into the side of the intake or does it push in/out?
All this talk about PCV valves has reminded me to replace mine, since it hasn't been done since I've owned the car.
To PCV and breathers question
