Throttle Position Voltage
Old Sep 11, 2004 | 08:50 AM
drumboytroy's Avatar
drumboytroy
Default Throttle Position Voltage
Hey guys,
If I raise my TPS voltage in the idle position say from .56 volts to the max which is .75 volts, according to my shop manual, will the ECM send me a little more fuel at WOT? Thanks, Troy
1985 L98, Stock ECM
Old Sep 11, 2004 | 11:07 AM
Upstate's Avatar
Upstate
From: [Quote=WOEII] Is dried brown doodie powders man! [/Quote]
No. The ECM will just see WOT that much sooner and start adding fuel accordingly.
Old Sep 11, 2004 | 01:07 PM
JAKE's Avatar
JAKE
Originally Posted by drumboytroy
Hey guys,
1985 L98, Stock ECM
Going to .75 will set a SES code - TPS Voltage High - and when that happens the ECM will revert to pre-programmed fuel maps. so don't try going that high.
I've gone as high as .67 without a code. Raising the voltage effects the air/fuel mixture during part throttle operation, so raising the voltage will richen the mixture.
It works on the same principle as the accelerator pump on a carb.
Jake
Old Sep 11, 2004 | 01:41 PM
NoWorries's Avatar
NoWorries
The ECM assumes you are WOT anything over 80% if I remember correctly, so you're not going to see any WOT improvement with 0.20 volts(4%).
Old Sep 13, 2004 | 03:14 PM
JAKE's Avatar
JAKE
Also, when you up the TPS voltage from, say, .54 to .64 you will feel a definite change with off-idle in the exhaust note and how the engine pulls.
In my case, the - off idle - the exhaust is slightly deeper, engine feels smoother, and SOP part throttle acceleration feels stronger.
Of course these are subjective; I've never done back-to-back testing at the strip or on the dyno to see the actual effect the change has on real-world performance.
Jake
Old Sep 13, 2004 | 03:41 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Bumping TPS voltage will not change WOT fuel or spark but will give a crisper throttle response.
The usual way to bump TPS base voltage is to increase it to .65Vdc at base idle of 450rpm. You could try bumping it to .75-.76Vdc at normal idle of 60-700rpm. If you get a code doing it that way just back off a hair.
If you want to add fuel at WOT, install an AFPR at the stock fuel pressure and then bump pressure for best performance.
Old Sep 13, 2004 | 04:18 PM
drumboytroy
Thanks man. I think that will be my next project. I also went to your site and looked at the procedure to reset base idle. CFI-EFI said that the ECM controlled that and burning a new chip was the only way to change it. I'm confused now. Can you help me? What RPM is base idle? What RPM is regular idle? Thanks, Troy
1985 L98
Old Sep 13, 2004 | 09:31 PM
CFI-EFI's Avatar
CFI-EFI
CFI said that the idle speed is controlled by the ECM. He did NOT say the BASE idle was controlled by the ECM. Changing the BASE idle (called the minimum air adjustment) will NOT change the normal (curb) idle speed, because the normal (curb) idle is controlled by the ECM. If you have a Helms manual, you need to spend some time with it. If not, go to: www,helminc.com
RACE ON!!!
Old Sep 13, 2004 | 10:50 PM
SunCr's Avatar
SunCr
CFI is
Old Sep 13, 2004 | 10:52 PM
SunCr's Avatar
SunCr
CFI is correct - There is nothing you can do to change the base idle. Crisp throttle response is dependent on having the minimum idle set correctly and the TPS at .54 +/- .06. Go above this number and the ECM will think the car is accelerating and it won't idle. Go below, and it will usually stall.
Old Sep 14, 2004 | 02:18 PM
drumboytroy
One Helms manual coming up! Thanks guys for the info. I'll go to my room and study.
To Throttle Position Voltage
