[Battery Charger] Where Do You Put Negative Cable?
Old Sep 11, 2004 | 01:15 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Default [Battery Charger] Where Do You Put Negative Cable?
Where do you attach the negative cable for a battery charger on a C4?
Old Sep 11, 2004 | 03:42 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I put both right on the battery terminals
Old Sep 11, 2004 | 05:37 PM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
Maybe. If you smell rotten-egg smell, don't connect to the battery as that is hydrogen-sulfide gas, which is explosive. In that case, connect negative cable to the frame of the alternator.
Old Sep 11, 2004 | 06:28 PM
comp's Avatar
comp
or connect then turn charger on
Old Sep 11, 2004 | 06:48 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Thanks, guys.
The manual to my battery charge (the one from Griot's Garage) says to connect the negative to some metal in the engine compartment (not the battery terminal). I do connect to the alternator frame.
It didn't make any difference - it looks like I've killed another battery...
Old Sep 11, 2004 | 07:17 PM
jfb's Avatar
jfb
The charger manual instructs you to connect negative to a ground away from the battery so that when you connect/disconnect the negative cable, if a spark occurs, you won't cause the hydrogen and oxygen gas from the battery to explode.
To [Battery Charger] Where Do You Put Negative Cable?
