EGR removal
Old Sep 14, 2004 | 04:03 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
Default EGR removal
Any one used a block off plate, and removed it completely.I have my intake off, and was contemplating removal after seeing the inside of my tpi system. Thanks Ron B.
Old Sep 14, 2004 | 04:49 PM
redbullapril23's Avatar
redbullapril23
yes i am taking mine off i bought the block off plate from tpis.com 12 including ship.
it will throw a code though to which you can get a special chip from this dude called
ski_dwn_it
azzatochips.com ...i think
unless its a 1996 in which case you can get lt1 edit and turn off your egr air system.
good luck
Sean
Old Sep 14, 2004 | 05:10 PM
C10 JDR's Avatar
C10 JDR
I made a plate, just a bit of 18 gauge stainless wth two holes drilled in it. You may or may not get a code 32. Doesn't really matter if you do apart from S.E.S. light on dash.
You can get it programmed out, and all the other mods you may have catered for too, from Jesse Azzato as above, among others. He did mine for me and I am well satisfied.
Old Sep 14, 2004 | 06:59 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I made 2 block off plates and eliminated egr tube and diaphram. I have had it this way for 6 months and no codes or problems. The only reason I did, was to clean up the engine bay. I also eliminated the air pump and its related crap. Valve cover removal is a snap as a bonus.
Old Sep 15, 2004 | 02:49 AM
white90conv's Avatar
white90conv
From a functional point of view, it is best to keep the EGR system. It reduces the tendency to knock at part load and there is evidence that it actually improves gas mileage. It is closed at full throttle so it does not cost any power.
To EGR removal
