Front transverse spring removal
Old Sep 23, 2004 | 01:35 AM
vettl83's Avatar
vettl83
Default Front transverse spring removal
Do any of you guys know a method to remove the front transverse spring without using spring compressing tool J-33432? Is tool J-33436-9 really a must have for removing lower ball joints? If these tools are a must have, is the locale Chevy Dealer the only source for these tools? Any help would be greatly appreciated. Thanks in advance. 84 CF 91 ZR1
Old Sep 23, 2004 | 02:18 AM
Wheelman's Avatar
Wheelman
You dont need a spring compressing tool. Just jack the car up really high in the front, remove abs sensors from front spindles, unbolt the sway bar, and shock from the bottom a-arm, and unbolt the spring bracket from underneath the front crossmember....Then put a jack under one side of the spring and unbolt the opposite lower a-arm......Let jack down, pull out spring from the side you removed the a-arm from
Old Sep 23, 2004 | 04:03 AM
Frizlefrak's Avatar
Frizlefrak
Yep, it's that simple. The tool they list in the helms manual is something they would have had in the dealerships back in the day. A floor jack will work just fine. There really isn't a whole lot of spring travel to deal with.
The only thing I might add is pick up a ball joint fork (free to rent at Auto Zone), place it between the ball joint and control arm, and give it a whack with a hammer and it will separate easily.
Old Sep 23, 2004 | 11:57 AM
Z51JEFF's Avatar
Z51JEFF
The tools are Kent Moore I believe.
Old Sep 23, 2004 | 03:19 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I wouldn't recommend a fork. Use a puller and press it out.
Old Sep 24, 2004 | 11:02 AM
vettl83's Avatar
vettl83
Thanks guys, I printed the posts so I don't have to look em up next spring when I install the lowering kit. This is my autox car and with 79k on the clock, I will replace the upper and lower ball joints along with all the front end bushings too. Vette Brakes and Products is going to love me. Again thanks, 84 CF the autox'er 91 ZR1 the retired autox'er.
To Front transverse spring removal
