1987 vette code 34
Old Sep 25, 2004 | 10:20 AM
mjfox's Avatar
mjfox
Default 1987 vette code 34
For those with a 1987 getting a code 34 mass air flow sensor and you have changed the sensor and just cant figure out the problem .It is a relay located neare the battery on the wheel well area .There are two there one needs changing cant handle the ampherage.
Mike
Old Sep 25, 2004 | 10:43 AM
vader86's Avatar
vader86
Yes, there are 2 relays, behind the battery on the firewall.
Those 2 must be changed anytime you change the MAF. Codes 34/36 can actually be either the relays or the Sensor.
Together, theyre about $20
