LT4 knock Module
Old Sep 29, 2004 | 07:13 PM
LT1Vetteguy78's Avatar
LT1Vetteguy78
Default LT4 knock Module
Hey guys,
My cars back in the shop....Mike's putting in a LT4 Knock Module...He said something about desensatizing the module....Is that going to help at all?
Old Sep 29, 2004 | 07:17 PM
mikey whipreck's Avatar
mikey whipreck
I know that helps alot on early l98's... by replacing the ESC module... i didn't know LT1/4's had the same solution
Old Sep 29, 2004 | 07:49 PM
MYCoupe's Avatar
MYCoupe
Originally Posted by LT1Vetteguy78
Hey guys,
It's suppossed to help if you have roller rockers or headers by making the knock sensors less "sensitive".
Old Sep 29, 2004 | 07:50 PM
STL94LT1's Avatar
STL94LT1
Default LT4 Knock Module
In the LT4 because of the increased valvetrain harmonics associated with the roller rockers, GM used a knock module that was less sensitive than the LT1's.
I'm using the LT4 K/M in my car, not sure how much it really helps.
I hope your not paying the shop much to install the K/M. Because it only takes about 5 minutes to do.
Old Sep 29, 2004 | 07:52 PM
LT1Vetteguy78
Nope not at all only paying for the part..like 25 bucks..he said it will help because the supercharger is so dam loud...
Old Sep 29, 2004 | 07:59 PM
STL94LT1's Avatar
STL94LT1
Default Knock Retard
I hope it helps. Were you getting alot of spark retard?
I have a supercharged Ford Lightning, and its knock sensor is turned off from the factory, because the supercharger is so noisy.
Old Sep 29, 2004 | 08:04 PM
LT1Vetteguy78
yeah i was getting allot he said this might help
Old Sep 29, 2004 | 08:07 PM
STL94LT1's Avatar
STL94LT1
Default Tuning
The LT4 knock module may help with a little spark retard. But, if you are getting alot, that needs to be addressed in the tuning.
Old Sep 29, 2004 | 09:04 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
$25 is a real good deal on one. I paid $28 plus shipping from GM Parts Direct. I put mine in after I installed 1.6 RRs and could tell a difference in so far as more consistent power.
To LT4 knock Module
