New Engine, or work on old?
Old Oct 2, 2004 | 10:07 AM
jimbomill's Avatar
jimbomill
Default New Engine, or work on old?
Any Pro's and Con's to consider for making my LT1 faster? Should I upgrade what God and Chevrolet gave me with the '92 convertible, or should I put in a new engine (from where/whom?) ?
Old Oct 2, 2004 | 08:30 PM
silver & red CE's Avatar
silver & red CE
IMHO, it depends. If you're going for 600HP and the motor has 200K miles, go for all new. If you're going for 400HP, you can get there without ever pulling the block.
What are you looking to do?
If you have an A4, you'll what to think about upgrading the trans and D36.
Eric
Old Oct 2, 2004 | 11:05 PM
jimbomill's Avatar
jimbomill
I have the 6-speed. I'm not looking for 600 HP, but 400, or a little better would have me grinning
Old Oct 2, 2004 | 11:18 PM
comp's Avatar
comp
your's Unless you got a Big wallet
Old Oct 3, 2004 | 08:33 AM
silver & red CE
If I was looking for 400Hp on an LT1:
Long Tube headers with cats ($1200)
pull the heads and have them ported ($1000)
LT4 HOT cam or CC 305 ($300)
CC or GMPP roller rockers ($350)
Catback ($800)
4.10 gear ($300)
That should get you close to 400HP (flywheel) 350 RWHP. If you do your own work, it'll run under $5000....
Eric
Old Oct 3, 2004 | 08:45 AM
STL94LT1's Avatar
STL94LT1
Catback ($800)
4.10 gear ($300)
Eric
Old Oct 3, 2004 | 09:17 AM
Red Tornado's Avatar
Red Tornado
Catback ($800)
4.10 gear ($300)
Eric
I agree very much, plus this is one of the more realistic budgets I've seen posted here. This will assume top quality components and parts, which is the only way to go
Add maybe $2,000 for labor, for a good job that's done correctly.
Old Oct 3, 2004 | 12:33 PM
tjwong's Avatar
tjwong
Don't forget to port the intake manifold to match the new ported heads. Otherwise your intake is going to be a restriction.
Old Oct 3, 2004 | 01:36 PM
SLOWRIDE's Avatar
SLOWRIDE
Old Oct 3, 2004 | 05:34 PM
jimbomill's Avatar
jimbomill
>Looks like a decent recipe to me. I actually have to check what gears are on the car already too.
Old Oct 3, 2004 | 05:36 PM
jimbomill's Avatar
jimbomill
Sounds like the "good labor" requirement rules me out
(It's been 20 years since I did engine work )
Old Oct 4, 2004 | 09:53 AM
dan85vette's Avatar
dan85vette
It's up to you but personally, I've been soo upset with "performance parts" prices... It's cheaper to just buy an engine with the specs you want!
It's frustrating to say the least...
Old Oct 4, 2004 | 11:09 AM
jimbomill's Avatar
jimbomill
Buy from where though?
Old Oct 4, 2004 | 07:57 PM
Strike3's Avatar
Strike3
Get the GM crate 383 with fastburn heads from Pace. Top it off with their TPI Vortec intake manifold and use your TPI system. I believe the engine is about $4,800.00 and the intake is $399.00. I would add Tpis Exhaust maniforl $750.00 and hi-flow cat $220.00
Your looking real close to the 600 HP and have a very streetably car.
Old Oct 4, 2004 | 10:38 PM
jimbomill's Avatar
jimbomill
Any fuel system mods or chip programming recommendations to go with that? I was hoping to keep cost closer to 5 to 6 K, any more and I'd be tempted to just buy a second '92 not a bad thought either ....
Old Oct 5, 2004 | 12:28 PM
Strike3's Avatar
Strike3
With any serious engine upgrade, you should probably upgrade the fuel pump, and I would select the TPIS level 5 chip. Do yourself a favor and Check with Pace Performance and TPIS prior to any decisions.
For the engine refer to part number 12498772 and manifold part number 12498060SD.
Old Oct 5, 2004 | 01:46 PM
USAsOnlyWay's Avatar
USAsOnlyWay
Whoa whoa whoa....
You are recommending a TPI to go on IN for an LT1???
They are different systems, I would not recommend going down to a TPI. Now buy a lt1 crate 383, and you're good to go.
I could be wrong, but I am pretty sure that would be more headaches than the reliable simple work mentioned above.
Disclaimer: I own a TPI 86, my new stroker will be a TPI run car, I love TPI
Old Oct 5, 2004 | 01:55 PM
silver & red CE
Gonna be a little bit leaky too
Gonna be tough to make this engine work in an LT1 car. The opti, PCM and ASR are all tied together. There's no way to put an opti on the GM 383. So you'll be forced to rework a bunch of systems....
Old Oct 5, 2004 | 05:04 PM
USAsOnlyWay
There, thats what I meant to say.
Minus that leaky comment....
To New Engine, or work on old?
