4+3 trans help
Old Oct 7, 2004 | 09:02 AM
The Rex's Avatar
The Rex
Default 4+3 trans help
I'm posting this for a guy I work with. He's got an 85 with a Doug Nash 4+3 trans. Where can he find an overdrive pan gasket? The Chevy house has been no help to him, so I said I'd try. Any suggustions?
All help is appreciated.
Old Oct 7, 2004 | 09:36 AM
nitrous1's Avatar
nitrous1
St. Jude Donor '06-'07-'08-'09
If he really want's one Try Eckler's or Mid-America. I bought my last one from one of them.
I'd suggest searching the archives on getting the OD pan to seal. I've had bad luck with using the gasket. The fluid seems to seep right thru the gasket after a few days. Scorp508 (I think) has a procedure in the archives for using only RTV to seal the pan. I'm going to try that next on my 86.
Good luck.
nitrous1
Old Oct 7, 2004 | 09:52 AM
Great White North's Avatar
Great White North
I agree .Just use the high heat atv.Make sure the flange on the pan is
hammered true ,and no leaky!!!!
da747's Avatar
da747
i bought one from ecklers.com.
Old Oct 7, 2004 | 11:46 AM
frank j. moran's Avatar
frank j. moran
RTV in my opinion does a much better job, clean surfaces with brake clean and you will be fine.
Old Oct 7, 2004 | 01:22 PM
The Rex's Avatar
The Rex
Thanks y'all. I'll pass the info on to him. He's had the car six years now. I'm surprised he's not a member here yet, but he will be soon.
Much appreciated.
Old Oct 7, 2004 | 02:00 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
tld-corvette, ecklers, mid america all have it.
I've had a bitch of a time getting the pan to seal... because it's hard to remove it without bending the flange.
Someone recommended using mopar transaxle RTV, supposed to be the best stuff there is.
It worked better than permaset's rtv, but still didn't seal it up.
ALso, the overdrive cooler lines will constantly weep atf onto the sealing surface and wash away the rtv. I disconnected the lines until the rtv had a chance to set up.
To 4+3 trans help
