Water pump drive shaft
Old Oct 7, 2004 | 10:32 AM
mitchcole's Avatar
mitchcole
Default Water pump drive shaft
I'm in the middle of the opti/timing cover/oil pan/water pump project. 92 LT1, 60K, 6 speed.
I've got the oil pan and timing cover off. I'm going with the meziere water pump. I need to remove the gear drive for the water pump. Do I have to take the timing chain off?
On the oil pan gasket - the FelPro gasket is sweet - the little corner holders! Bitchin' Am I supposed to use any silicone with this install?
I'm not planning on replacing the timing chain.
The new opti is the dynaspark.
Old Oct 7, 2004 | 10:42 AM
Strick's Avatar
Strick
I know it's a little long, but here is an article I did for the Tech-Tips:
https://www.corvetteforum.com/techti...=231&TopicID=2
I think I explained how I got the water pump driven gear off using a tool designed just for this. It's a horse shaped puller that fastens around the shaft. Most of it was in my Helms manual. I also explained how I plugged the hole in the timing cover. If you have anymore questions about it just ask. I did mine a couple of years ago and it's still running great.
Old Oct 7, 2004 | 10:49 AM
mitchcole's Avatar
mitchcole
I know I explained how I got the water pump driven gear off using a tool designed just for this. It's a horse shaped puller that fastens around the shaft. I also explained how I plugged the hole in the timing cover.
Strick - I printed out your tech tip awhile ago - it's been the bible for this project. However I don't see the part about the water pump gear?
The timing cover is already plugged - I just need to get that shaft off. It's sort of nestled behind the timing chain - did you pull off the timing chain?
Old Oct 7, 2004 | 10:53 AM
Strick's Avatar
Strick
Did I pull my timing chain? Yes I did as the driven gear messes behind the cam sprocket.
Old Oct 7, 2004 | 08:11 PM
mitchcole's Avatar
mitchcole
Strick - By the way - Thank You!
The tech tip has been very valuble. Thanks for taking the time to write it. My beer breaks seem to be more often though....
Old Oct 7, 2004 | 08:38 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Why change the gear?????
Old Oct 7, 2004 | 08:47 PM
mitchcole's Avatar
mitchcole
Why pull the gear - to eliminate an oil leak location. Plus - an unsupported shaft is going to get all of it's structural needs from the oil seal. That can't last long.
Here's the gear in question:
To Water pump drive shaft
