Spark advance question
Old Oct 14, 2004 | 02:14 PM
black_89_vette's Avatar
black_89_vette
Default Spark advance question
On a datamaster log, I noticed on cruising that the spark advance was 36.0 degrees and when I go WOT it was 33.0 degrees.
Is the total timing the spark advance + base timing?
If so, does that mean since my base is 6 degrees and my advance is 33, that at WOT my total timing is 39 degrees, and at cruise speed it is 42?
Does this sound like too much?
I am trying to track down a knock retard issue and was wondering if there is too much timing in my chip.
Old Oct 14, 2004 | 07:12 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Total timing is 33* including the 6*. So your base is 6*+ your advance of 27* for a total of 33*
At cruise you want much more timing than WOT, hence the 42*. Since your not packing the cylinders as much, the cumbustion is not as efficient and it needs a little more of a head start to give good results.
Old Oct 15, 2004 | 12:32 AM
black_89_vette
So, in Datamaster when it says spark advance is 33 degrees at WOT, then the total timing is 33 degrees?
I thought that when it said spark advance was 33 degrees, the total was the base + spark advance.
**EDIT**
Hey Ski, I just bought a Power Programmer 2, but the Datarase 2 didn't come or show up on my credit card for some reason, so I'll have to order one from a different company.
But in the mean time, when I get my adapter rigged up (so my Memcal will connect to the programmer without taking things apart) I can read the .bin file and post it for people to look at. I know there's problems with it right now.
To Spark advance question
