DFI question???
Old Oct 14, 2004 | 06:53 PM
zelement's Avatar
zelement
Default DFI question???
I am replacing my 42# FORD high impedence injectors with Delphi 72# low impedence injectors. My questions is, Does the DFI know the difference between high and low impedence? I don't see where I can input this information into the DFI. Does anyone know?
Thanks,
Paul
Old Oct 14, 2004 | 09:29 PM
tjwong's Avatar
tjwong
Thanks,
Paul
Paul, all you have to do is to define what size the injectors are in the setup. The DFI ECU will take over from there. In its internal firmware and circuitry it will know if its low or high impedance. Let me know how it runs. Did you ever get a definitive answer on the cam and valve float issue?
Check out Mo's web page: http://www.ndneyes.com/mo/super.html
Old Oct 15, 2004 | 12:39 AM
zelement's Avatar
zelement
Thanks Tom,
I spoke to Comp cams and they suggested switching to their behive spring setup. I ordered them and will try it out. Their explanation is that the retro fit lifters I am using are heavier that is why I am floating the valves.
To DFI question???
