heated o2
Old Oct 19, 2004 | 10:21 AM
corvette90's Avatar
corvette90
Default heated o2
hi all
want to install LT headers on my L98 and switch to a heated O2
are there any things to look at? (except the heating curcuit)
can i use a universal heated o2 or will it have to be a special one??
thank you
Old Oct 19, 2004 | 11:43 AM
mos90's Avatar
mos90
Get a bosch 3 wire heated o2. the only thing you need to do to install is a ground wire and a keyed power wire.
Old Oct 19, 2004 | 11:58 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I don't think the O2 heater draws much power but if it does you would need to add a relay and a fuse.
Old Oct 19, 2004 | 12:12 PM
mos90's Avatar
mos90
it doesnt draw enough juice to require a relay or fuse.
Old Oct 19, 2004 | 01:26 PM
corvette90's Avatar
corvette90
thank you, that was what i wanted to hear..i have a relatively cheap source for bosch´s, just wanted to verify that it will work (altough i think, all Zirkoniaoxide O2 should work the same way)
thank you
Old Oct 20, 2004 | 01:15 AM
vettenut85's Avatar
vettenut85
you can use bosch #13077.about $49 at autozone
Old Oct 20, 2004 | 08:24 AM
Red Tornado's Avatar
Red Tornado
also, this will help you for the install:
https://www.corvetteforum.com/techti...D=93&TopicID=2
you made a good decision on going with the heated setup. good luck!
Old Oct 20, 2004 | 02:36 PM
corvette90's Avatar
corvette90
hi all
first thank you for your help....i ordered an NTK, its the same as the Bosch, its about 1 $ cheaper...heated Bosch´s are not available at the moment
for those who are interested: www.uni-fit.de
i know, its a german site, but i live in Austria.....
Old Oct 20, 2004 | 03:48 PM
Red Tornado
Old Oct 20, 2004 | 03:51 PM
aklim's Avatar
aklim
I had shorty headers on my Firebird but I am not sure about the long tube headers for my Vette. I understand the reason but for summer driving and spring and fall but no winter driving, would it make a difference?
To heated o2
