400 Small Block Ideas
Old Oct 22, 2004 | 07:31 PM
vsocks's Avatar
vsocks
Default 400 Small Block Ideas
Just got my hands on a standard bore 400 small block, 4 bolt #1511 casting. Looking for ideas for crank, pistons, cam, etc for starters. Want a 400HP+ street/strip car naturally aspirated. Should I consider a 421, or less?
I am willing to sacrifice some driveability, but I have to drive 50 miles to get to the track. Also would still like some weekend cruises around town.
Looking for some ideas and I am taking my time on this build. 700R4 Auto tranny and 3.07 gears right now.
Old Oct 22, 2004 | 07:36 PM
CFI-EFI's Avatar
CFI-EFI
Don't go nuts on the hp in a 4 bolt main 400 block. That is the weak sister of the 400 family. You MIGHT be OK with only 400 hp.
RACE ON!!!
Old Oct 22, 2004 | 07:43 PM
chriswtx's Avatar
chriswtx
It will be easy to make 400hp. Cam Hyd/roller in the 230 range, crank 3.75 stroke eagle, 6" eagle rods, SRP pistons 10.5 to 1 comp., Have the rotating assembly internally balanced, Heads Brodix Track1 cnc ported, intake SuperRam or Mini ram take your pick, 1.6 roller rockers, fluidampner, it would probably put you in the 500hp range...
As for the 400 4bolt block I'm with CFI they are known for being weak. It is better to convert a 2 bolt 400 to a splayed 4 bolt. The other option is to by an aftermarket block...
Old Oct 22, 2004 | 09:22 PM
vsocks's Avatar
vsocks
I got the 400 block reasonable, $150 but it is a 4 bolt. Should I stop now and sell it for a 2 bolt? I may want over 400HP, maybe 450-500HP.
Old Oct 22, 2004 | 09:59 PM
chriswtx's Avatar
chriswtx
If you are looking to make more power and you want it to be bulletproof ditch the 4 bolt and find a 2 bolt or spend the $$$ for an aftermarket block...
To 400 Small Block Ideas
