L98 Alternator Eater
Welcome to the world of L98 alternators.
The only way around this issue is to do one of three things:
1) Find a good rebuild shop in town and have them make you a killer alternator, with larger bearings. This is usually the first thing to go on them. The circuitry is also a little flakey, and a good rebuild shop can give you something that will hold up.
2) Put underdrive pullies on the car. At 5000 RPM I believe the alternator is turning something like 24,000 rpm. It might not be that bad, but is is something crazy like that.
3) Install a fuel cell in the thing and never worry about it again.
I think with this option, you might be able to get some federal funding for the experiment.Good luck to you. I've been through 5 of them myself, before I went and had one built for me. It has been 2 years now, so I'm almost at the point where the rest failed. I know a few people, (you know...the kind that turn their cars into rolling boom boxes) that had 300 amp units built.
In each case, it was the bearing that crapped out. The new one is supposed to have a higher quality bearing, and other parts.
The fact you have the problem in July may be due to heat and/or a problem with or compounded by more use of the A/C.
My stock alternator was replaced under warranty with a GM reman and then failed a couple years and not a lot of miles later.
I have PepBoys "Lifetime" alternators on my '89 and on my truck, both a 4 years now no problems. I hear the AutoZone "lifetime" warranty ones are good too.
http://www.corvetteforum.cc/ubb/Foru...ML/009586.html
ive had thsi happen on both my firebirds...
the alternator died.. the battery was drained... i got a new alternator and it died a few days later.. then i got a new battery adn a new alternator at the same time and it was all good. This is what 2 different auto parts places told me when they sold me the alternators... just to get a new battery OR make sure the old one is fully charged before starting with the new alternator..
hope that helps
