Need Performance Improvement Help
Old Oct 23, 2004 | 05:05 AM
James93LT1's Avatar
James93LT1
Veteran: National Guard
Default Need Performance Improvement Help
Waited many years and I finally got me a nice 93 LT1, A4. I'm currently in the plan to up grade my Vette with some 354 gears first, K&N open air filter, and some 1.6 roller rocks with LT4 springs, guide plate, and harden push rods. My questions is how do I go about recalibrating the speedometer with the new gears, and will I need a performance chip burned to this new configuration?
Thanks...
Old Oct 23, 2004 | 06:39 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You will need to change the speedo pickup gear in the A4 to calibrate the speedo to the new gears.
You won't likely need a new chip burned but an AFPR would be handy so you could bump fuel pressure a few pounds above the current value, as measured at idle with the vacuum line disconnected.
Old Oct 23, 2004 | 07:03 PM
James94LT1's Avatar
James94LT1
Just thought I'd Say Hi James93LT1, thats funny, I am James94LT1!
Can't gpo wrong with a name like that! Welcome!
Old Oct 23, 2004 | 07:07 PM
Perfusion's Avatar
Perfusion
Thanks...
IIRC, a Hypertech PowerProgrammer III will do gear change correction for speedos. Another way is the chip method, or you can change the physical speedo gear.
At any rate, welcome to CF!
Old Oct 23, 2004 | 10:02 PM
James93LT1's Avatar
James93LT1
65Z01... Thanks for the info, gives me the direction I needed, and will add the AFPR to my next to do list.
James94LT1...Thanks for the welcome, Love my new Corvette
Perfusion... Thanks for your info and welcome, can't wait to get all the mods in my Corvette
To Need Performance Improvement Help
