"Which do you trust"?????????
Old Jul 21, 2001 | 12:57 PM
9C4403's Avatar
9C4403
The anolog guages. Or the needle guages. Mine do not seem to read the same .?? What would you say the normal operating range is for the oil temp?? @ 102 deg?????(outside)
Old Jul 21, 2001 | 01:12 PM
Kale's Avatar
Kale
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:[/color]<HR><font face="Verdana, Arial" size="2"> The anolog guages. Or the needle guages [/color][/QUOTE]
Same thing!!
Old Jul 21, 2001 | 01:15 PM
mikes84vette's Avatar
mikes84vette
i live right next door to you in louisiana, and my oil temp will range from 225- 235. i have seen it as high as 243 on my car.
Old Jul 21, 2001 | 01:28 PM
9C4403's Avatar
9C4403
OK, i'll rephrase the ????? Digital/Anolg!!! (Digital-numeric readout)
(Anolog- needle guages)
Which do you trust????????
Old Jul 21, 2001 | 01:36 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Mine are the same way. It appears that the analog gauges always read lower than the digital.
I started watching the digital after I installed a 160 stat.
The analog temp gauge used to hit 245 -250 on occasion. Now the digital shows 180 or so and the analog is displaying way low at around 130. Makes me wonder how hot the car really was running????
My analog oil temp gauge never goes over about 140; digital shows 180 - 200.
Old Jul 21, 2001 | 01:45 PM
KLLRVET's Avatar
KLLRVET
When these cars were new, there was some sort of sticker on the gauge cluster that stated that the anolog gauges were not properly graduated or something to that effect. I cannot remember exactly what it said. Also the sending units for the anolog gauges are in a different location than the digital ones so there will be some sort of variance. I have also noticed when I use Diacom, the readings I get are different from either the anolog or the digital gauges.I am not sure if any of them are actually correct.
Tony
Old Jul 21, 2001 | 07:47 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
In the manual, it tells you what the approx temp is on the anolog for each mark. The middle mark isn't necessarily the halfway point.
Also, someone told me that the sensors for the digital are in a different place than teh analog, therefore you would get a different reading.
Old Jul 21, 2001 | 07:50 PM
MY 95's Avatar
MY 95
CI 2-3-4-5-6-8-9 Veteran
St. Jude Donor '05-'06-'07-'08
when i n doubt, i follow the digital guages
Old Jul 21, 2001 | 09:24 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Old Jul 21, 2001 | 09:49 PM
VMAX451's Avatar
VMAX451
The analog guages are non-linear, which to
me translates to non-human-readable without
some serious mental calculations.
Completely useless unless they are in the
"danger" zones. The digital ones are more
useful to me, but you can only have one
up at a time, at least on my '92.
Same thing on my GM pickup truck. Funny that
they put useless tick marks on the guages.
Purely a styling exercise. Being an engineer,
all this ticks me off!
Vince
'92 Z07/ZF6
Old Jul 22, 2001 | 02:08 AM
Raysur's Avatar
Raysur
My oil temp gauge never hits it's first mark but my digital gauage reads 203. I trust the digital gauge.
I'll bet no one has a working oil temp gauge.
Old Jul 22, 2001 | 02:52 AM
BaseballDude's Avatar
BaseballDude
I tend to keep the digital water temp gauge on full-time. The oil pressure analog gauge is in good view and accurate enough to let me know I'm running at least 40psi at 1,000 rpms and higher.
The rest of the small analog gauges on the right side of the pod just take up space and are pretty useless.
Old Jul 22, 2001 | 03:00 AM
Pasterli's Avatar
Pasterli
Digital. My analog pegs from time to time, but when it is reading it always matches the digital. Your computer reads off the digital sensor, so thats what your computer is going by.
Old Jul 22, 2001 | 05:27 PM
GlockLT4's Avatar
GlockLT4
I always read the digital guages. Except for the oil pressure guage, ovbiously, since that isn't an option on the digital cluster.
Old Jul 22, 2001 | 11:20 PM
R23HTC's Avatar
R23HTC
I ocassionally saw the analog pegged in the temp zone, only to see the digital about 20° less. I'm praying the digital is usually right.
To "Which do you trust"?????????
