Headlight Motor
Old Oct 25, 2004 | 11:50 AM
Blue260's Avatar
Blue260
Default Headlight Motor
I recently purchased nylon bushings from Mid America to repair the passenger side headlight motor.
Can someone please tell me how to remove the motor assembly. Does the whole housing have to come out or can I just remove the motor.
I sure could use some advice!
Thanks, Chris
Old Oct 25, 2004 | 12:30 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I had to remove the assembly from my '88 so that I could drive out the drift pin from the motor shaft.
Then the motor assy. could be separated from the headlight.
Old Oct 25, 2004 | 01:23 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
You need pics homeboy. Click this. And oh yes, the WHOLE assembly must come out.
http://www.corvettefever.com/howto/33098/
Old Oct 26, 2004 | 07:59 AM
Blue260's Avatar
Blue260
Mucho Thank You - You not Da Man - You IS Da Man!
chris
Old Oct 26, 2004 | 08:20 AM
onedef92's Avatar
onedef92
chris
Few things delight me more than helping a fellow Corvette enthusiast.
You holler back here if you run into any snags. If you accidentally break a motor brush or something like that (heaven forbid) I can help you with that, too.
To Headlight Motor
