Chip??
Old Jul 23, 2001 | 03:42 PM
whiteLT1's Avatar
whiteLT1
How much will a chip help out a 92 LT1 with ram air, 160 thermo, flowmaster cat back,& throttle body bypass? Which is better Hypertech or fastchip? Thanks
Old Jul 23, 2001 | 08:56 PM
Carroll B's Avatar
Carroll B
I don't know how you could install a gernic chip without knowing what your engine is doing first. Check out the article under the C4 tech tips section. Most after market chips advance the timing under WOT. I had to decrease mine as the knock sensors were already starting to retard the timing in the stock chip. I also found out my engine was running rich at WOT.
Old Jul 23, 2001 | 11:39 PM
whiteLT1's Avatar
whiteLT1
Please help!! What would a chip do for me? How much of a gain if any??? Thanks
Old Jul 24, 2001 | 07:41 AM
vettenuts's Avatar
vettenuts
It depends on what type of help you are looking for from the chip. I see you have a 160 stat, but have the fans been reprogrammed to take advantage of it? I don't think you will see a huge performance gain, but you may realize some driveability enhancements such as when the torque converter locks up and the fans on/off temps setup for the lower temp thermostat. Given a choice between the two chips listed, I would go with the Fastchip.
Old Jul 24, 2001 | 07:54 AM
Lloyd Smale's Avatar
Lloyd Smale
it makes a noticeable difference in my 92 but mostly in drivability tc lock up fan op. ect. but it does seem to have a little more power also
Old Jul 24, 2001 | 08:33 AM
GlennS87's Avatar
GlennS87
If you plan on continuing to mod your vette, learn how to do it yourself. There is a DIY Prom forum at www.thirdgen.org. Lot's of good info on getting started. This is the only way to get the "best" chip for your car.
If you are not, go with fastchip. The hypertech is a waste of money.
Old Jul 24, 2001 | 11:59 AM
Warlock's Avatar
Warlock
If you want it do it yourself, check out the link in my sig for tons of info.
To Chip??
