help help exhaust
Old Oct 26, 2004 | 05:57 PM
rugby!'s Avatar
rugby!
Default help help exhaust
91auto i have the stock catback off and i have the clamp off of the cat and i want it off to gut it and put it back with my new magna flow catback..........but i can't figure out how to get the cat air injection pipe(i hope that is what it is called) disconnected. there is a ring(?) around the pipe about 4" from where the pipe goes into the cat, is that what i need to remove and how? if that is not where i get the pipes apart please help. i want to get the vette back on the road ........
jeff
Old Oct 26, 2004 | 06:32 PM
mikey whipreck's Avatar
mikey whipreck
you've got mail
Old Oct 26, 2004 | 07:59 PM
89vert's Avatar
89vert
jeff
That is where you want to take it apart. I used a torch to heat the clamp and used a screw driver to pry it open. When I put it back together I heated it and squeezed it back together with wire cutters. This worked well for me.
To help help exhaust
