Opti fail with Delteq?
Old Nov 1, 2004 | 08:15 AM
jimbomill's Avatar
jimbomill
Default Opti fail with Delteq?
As the write-up for the Delteq opti replacement says to leave the opti in and further it says it uses signals from the Opti, doesn't it not quite solve all the problems of the opti?
Old Nov 1, 2004 | 08:38 AM
96GS#007's Avatar
96GS#007
The Delteq (and I believe the LTCC) reuses the optical signal from the opti. This portion of the opti rarely fails.
In general failures are a result of cap and rotor and/or the bearing failures.
Old Nov 1, 2004 | 09:28 AM
mitchcole's Avatar
mitchcole
Can you install a LTCC system with a bad opti? It seems like a shame to have to install a new opti AND the LTCC kit.
With newer parts, I'd heard that the LTCC will last longer due to the absence of high voltage in the opti.
Old Nov 1, 2004 | 10:10 AM
FD2BLK's Avatar
FD2BLK
If you are thinking of either the Deleq or LTCC then I would recomend just installing them before replacing the Opti and see if it corects the proble (Probably will). You have nothing to loose using the old units Low voltage side and if it is bad you can then replace it with nothing lost. The odds are that if your opti is dead and has set no codes, that is the cap/rotor, high voltage portion, as others have stated.
Old Nov 1, 2004 | 10:22 AM
SLOWRIDE's Avatar
SLOWRIDE
Old Nov 1, 2004 | 12:25 PM
jimbomill's Avatar
jimbomill
I'm betwixt and between - the Dynospark, as I read it, is a replacement. The Delteq is a "add-on" or piggy-back setup. Both appear to be positive upgrades and I'm not sure why I cannot make up my mind between them
Old Nov 1, 2004 | 08:30 PM
96GS#007's Avatar
96GS#007
Here's my opinion (this and a buck will buy you a cheap cup of coffee):
The benefit of the Dynaspark is that it won't leak if it gets wet like the earlier Opti units and it's vented ('95 & up units were pretty well sealed and are vented..."FYI"). It retains the factory look from the topside of the engine. The downside is it still uses an OEM opti cap and rotor and those wear out. Sure, the cap can be replaced but it's not cheap and it's a PIA.
The benefit of the LTCC or Delteq is that neither of them use the opti cap and rotor so they eliminate the major failure mode. Some like the looks of these setups others do not, but in either case the engine clearly doesn't look stock.
Having said all the above, how often does the opti really fail? Maybe you drive the car a lot and end up changing one every three years. You'll have to own the car another six years before one of the alternatives breaks even from a cost standpoint.
Old Nov 1, 2004 | 11:05 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I still have my bad opti in the car with the LTCC.
Old Nov 1, 2004 | 11:06 PM
jimbomill's Avatar
jimbomill
Sound advice - thanks - and I like cheap coffee
Old Nov 2, 2004 | 10:21 AM
Nathan Plemons's Avatar
Nathan Plemons
Of all the failed opti sparks I've ever seen only ONE was ever a cap/rotor issue. Every other one has been some problem with the "brains" of it, which is exactly why I'd never spend a ton of money on a system that is now just as likely to fail.
Old Nov 2, 2004 | 01:06 PM
bogus's Avatar
bogus
That is most interesting.
OF all the opti failures - including my own - only 1 has been related to a code/brain failure.
The brain, as you call it, is made by Mitsubishi. A friend of mine at a Dodge dealer back home has told me that the Mitsu optical pick ups, which appear identical to the OptiSpark's pickup, very rarely fail.
And from forum experience, the majority, symptomatically, are failures of the cap/rotor.
It is with this body of experience, I went with the LTCC. The opti in my 92 has been there for nearly 4 years and 70k miles. Knocking on wood, no sign of coding.
My original opti had been hit with coolant, the bearings were crap. I have no info on the current condition of my opti's bearings.
Old Nov 2, 2004 | 07:21 PM
96GS#007's Avatar
96GS#007
I've never had an Opti fail with a code and I've been thru a few of them. I did replace one unnecessarily while trying to fix my high rpm miss (which for no apparent reason disappeared after my engine rebuild ).
Old Nov 2, 2004 | 07:30 PM
James94LT1's Avatar
James94LT1
I have been plagued with OPTIS since my head cam swap! My car eats them like a fat kid eats pizza! Got the LTCC installed in on my failing opti and everything was good to go Like MOJO said. I have never spent the time to tear one of the 5 I have killed apart to see what was actually wrong but I can tell you that when you shook them there was many loose pieces clanking around inside. I assume the is the rotor self destructing from 7k RPM Rips!
Old Nov 2, 2004 | 10:41 PM
bogus's Avatar
bogus
uh, you think???
I woulda pulled one apart to check that out...
Old Nov 3, 2004 | 08:41 AM
Tom Piper's Avatar
Tom Piper
Interestiing, my experience has been just the opposite -- none of the ones I've seen have been related to the bearing, oil intrusion, missing low-res or high-res pulses. They have all been carbon tracked caps or destroyed rotors.
Tom Piper
To Opti fail with Delteq?
