error code 34and 43
Old Nov 2, 2004 | 08:36 PM
legsandvettes's Avatar
legsandvettes
Default error code 34and 43
ok i keep getting a 32 and 43 code, engine light comes on and car runs like crap, ie...no power and seems like it misses, or starvin for air, and way i put in my key to run diags, then the engine light goes out and car run great, 43 is a knock sensor, but i think it may be coming up as well, cause of the 32, which i understand is a maf sensor, or ecm, other than testing ohms, on the maf, is there another way to isolate the problem, and can it be a map sensor a s well, cause if its bad it also throws a 32....thanks by the way i have an 87, with a 4+3
GO BUSH
Last edited by legsandvettes; Nov 2, 2004 at 08:40 PM. Reason: FORGOT TO EXPLAIN MY YEAR VETTE
Old Nov 2, 2004 | 08:42 PM
legsandvettes
Default sorry 34 and 43
sorry my mistake, a 34 and 43 code
Old Nov 2, 2004 | 08:53 PM
mikey whipreck's Avatar
mikey whipreck
I have a current thread up about how i fixed my code 43.... you could give it a look...
Old Nov 2, 2004 | 11:11 PM
SunCr's Avatar
SunCr
Your year doesn't have a MAP, but if you're using a generic shop manual, it's easy to get confused. Make sure the air tube is tight and not leaking air and then the best test for the MAF is to disconnect it and see if it will at least start and stall - After it stalls, see if it will start and run. If so, you probably need a new MAF. Otherwise, the relay may be shot. See if there is battery voltage to the MAF on the Purple wire, terminal E, with the key on. If not, the Relay may be all you need. If the voltage is there, it's probably still the MAF.
For the 43, check the connection at the knock sensor.
Old Nov 3, 2004 | 02:24 AM
bogus's Avatar
bogus
I have found that weak or failing MAF sensors can cause all sorts of drivability problems.
check the wire to the knock sensor, its near the exhaust, and that wire can break.
check out my "sticky" post at the top of the page regarding early C4s.
Old Nov 3, 2004 | 09:47 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Here is some guidance
http://members.shaw.ca/corvette86/Code%2043.pdf
http://members.shaw.ca/corvette86/Code%2034.pdf
Old Nov 3, 2004 | 12:29 PM
88421VETTE's Avatar
88421VETTE
I had same Code replaced maf car runs fine :cheers!:
To error code 34and 43
