Clearing trouble codes?
Old Nov 3, 2004 | 11:12 AM
CP5150's Avatar
CP5150
Default Clearing trouble codes?
Got a 96 LT4. I am looking to clear the trouble codes and get the SES light to go off. I don't have a scanner or code reading software, had Auto Zone check the codes. OBD 1 you could pull the ECM fuse for ten seconds and clear the codes. Tried it on the 96 and it didn't work. I would prefer not to disconnect the battery as I don't want to lose the PKE key fobs and have to redo them. If it's the only way it's not that big a deal I guess. Thanks.
Old Nov 3, 2004 | 12:29 PM
96GS#007's Avatar
96GS#007
The key fobs don't lose their memory when you disconnect the battery.
To clear the codes after fixing the problem, disconnect the battery or pull the PCM fuse.
Old Nov 3, 2004 | 12:35 PM
ravenlunatic's Avatar
ravenlunatic
Veteran: Marine Corps
Old Nov 3, 2004 | 12:57 PM
CP5150's Avatar
CP5150
Sorry, I thought I read here if you pull the battery for winter storage, the PKE forgets the codes for the fobs and they need to be reset. I don't see a PCM fuse. ECM, CCM 1, 2, and 3 too. Maybe I'll just disconnect the battery. Thanks guys!
To Clearing trouble codes?
