Help w/ Sudden Idle Problem
I'm in San Antonio, TX, and we've had about 12 inches of rain over the last couple of days so my first thought was something got wet or I got water in my gas somehow, but wouldn't this affect it across the entire RPM band and not just at idle?
The first thing I did was look for a vacuum leak but couldn't find any. As soon as my wife gets home from work I'm going to go get a new fuel filter and see if that helps. If not, can anyone offer any advice as to where to look next?
The car's an '89 L98 coupe, 79k miles, and stock.
Thanks in advance for help.
Any codes???
It might be dirty or in need of adjustment.
First, make sure it's still connected!!! That happened to me once! oopsie.
It's on the right side of the throttle body, at the bottom of the TB. It has a square connector with 4 wires.If thats ok, remove the intake tube and look inside the TB. I'll bet it's nasty! At the bottom of the inside of the TB, near the throttle plates, is a smallish hole. That is the IAC port. Get some carb/injection cleaner and soak it all over. Inside that hole, mostly! I have seen chunks of crap flow out....
If it runs better after this GREAT!
It might not be a bad idea to pull the TB and clean it completely. It is not hard to remove, will require a new gasket, tho...
if you remove the IAC, it will REQUIRE a special reinstall process. Move the pintle out 28mm from the edge of the IAC body (this includes threads!).
DO NOT TURN ON THE ENGINE WITH THE IAC ATTACHED AND IN INSTALLED!!! IT WILL EXPLODE!!!
In mine, once the car was warmed up (closed loop I think it is) I would get a continuous Idle surge fromm 600-900 RPMs while Idling.
I replaced the IAC
it now idles steady at 600 RPMs when warmed up...
You did say this only happened after it got really wet...
The distributer getting wet would be my second guess then.
Luckily you have an L98, and once it dries off you should be fine if that's the case...
Good Luck and hope it doesn't cost you much.
These cars are very susceptible to not just loose connections but also to "dirty" connections.By dirty I don't mean that it has to be corroded "green"!
Both the positive and negative leads servicing the sensors are "stacked" one atop another and secured to common distribution blocks.
According to the Guru, Gorden killebrew, GM experienced a lot of problems in Texas, Virginia and North Carolina with high humidity "corroding" these connections.
Again, don't mean obvious "green", but barely visible signs! These sensors are operating on minivolts/amps and slight changes in resistance can affect performance.
Last fall and spring I was chasing numerous electrical gremlins, including some that were transient. While I had some bad relays (MAF) and the IAC, it wasn't till I undid all the positive and negative leads and cleaned them that my problems not only went away, but the car is running better than ever
All the leads "looked clean", but apparently an invisible layer of "corrosion" had set in.
On my 88 all the positive leads attach to a block behind the battery and the negative ends bolt to the transmission case.
Jack
