'89 vette won't keep running
Old Dec 3, 2004 | 10:01 PM
rbohrer318's Avatar
rbohrer318
Default '89 vette won't keep running
My '89 wouldn't start this morning. It would crank and run for about 5 seconds and then stop. Thinking it was fuel related, I changed the fuel pump and the fuel filter. It still wouldn't keep running. I checked for codes and got a code 33. I disconnected the MAF sensor and now it starts and runs okay. I replaced the MAF sensor but, when connected, the motor kills. I bought a new MAF sensor and relays and the same thing happens. Anybody got any ideas?
Old Dec 3, 2004 | 10:51 PM
richdwyer's Avatar
richdwyer
Are you sure you changed the right relays? The relays for the MAF are the 2 behind the battery. There are a couple relays by the wheelwell that are for the cooling fans. The relays all look alike, so it would be easy to change the wrong ones. If this isn't the problem let me know, I have an 89 and can e'mail you the troubleshooting chart out of the factory manual. good luck Rich
Old Dec 3, 2004 | 11:19 PM
rbohrer318's Avatar
rbohrer318
Yep, changed the relays behind the battery. Checked the wiring diagram before I did it. I just can't figure out what it going on.
Old Dec 3, 2004 | 11:23 PM
Sam Lam's Avatar
Sam Lam
Since you replaced the parts, are there any codes?
Old Dec 3, 2004 | 11:34 PM
rbohrer318's Avatar
rbohrer318
got a code 33 and it won't keep running unless I disconnect the MAF.
Old Dec 3, 2004 | 11:37 PM
rbohrer318's Avatar
rbohrer318
Default 89 vette won't start
got a code 33 and it won't stay running unless I disconnect the MAF
Old Dec 3, 2004 | 11:38 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
This flow chart may help you if you don't already have it
http://members.shaw.ca/corvette86/Code%2033.pdf
Old Dec 3, 2004 | 11:43 PM
rbohrer318's Avatar
rbohrer318
I really appreciate all the help guys; the more info the better.
Thanks.
Old Dec 5, 2004 | 09:32 PM
Zebraitis's Avatar
Zebraitis
I have an 89, and sufered problems when idleing... It was the injectors.
Have you ever had them resistance tested? You may want to take that into the shop and do that.
The age of our rides, the insulation breakes down.
Good luck!
To '89 vette won't keep running
