Outer window felt install problems
Old Dec 4, 2004 | 08:35 AM
Fastmax32168's Avatar
Fastmax32168
Default Outer window felt install problems
Ok for a guy who can do about anything on a car I feel like a total idiot right now. I have been trying for about an hour to install a new drivers side window felt. I cannot get the little clips to catch in the holes. I tried tightening them up a bit and also loosening them a tad. It looks like the problem is I cannot get it to drop low enough for them to pop into the holes. Am I going to need to pull the window to do this or is there a trick to it? Thanks,
Roy
Old Dec 4, 2004 | 08:42 AM
Chatman's Avatar
Chatman
Have you read the techtips article on window felt replacement? I found it to be very helpful when I did the job.
Steve
Old Dec 4, 2004 | 08:57 AM
Fastmax32168
I just went and looked at it. Unfortunately mine is not going as easily as portrayed. It will not push down far enough for the clips to catch. Suggestions please?
Old Dec 4, 2004 | 09:44 AM
Fastmax32168
Got it. Looks like one of the clips on the replacement slip didnt line up correctly with one of the holes. Its the simple things that get ya.
Old Dec 4, 2004 | 10:14 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Where did you get the replacements? THere is a difference between the genuine GM and the aftermarket. The aftermarket are the ones that are hard to install correctly and they make you curse a lot....a lot!
Old Dec 4, 2004 | 01:27 PM
Fastmax32168
No aftermarket. The general himself was responsible for that one.
Old Dec 4, 2004 | 07:51 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I had the same problem with new G.M. seals. I had to brake one of the tabs off
To Outer window felt install problems
