Body Glue
Old Dec 4, 2004 | 10:54 AM
beachbumskip's Avatar
beachbumskip
Cruising
Default Body Glue
I'm reattaching the rear body panel on my 90 Convertible. What's used to glue the body panels together. Thanks
Old Dec 4, 2004 | 11:05 AM
Pete K's Avatar
Pete K
A 2 part epoxy made by Lord chemical is used to bond smc panels. It is available from Ecklers and you local auto body paint supplier.
Old Dec 4, 2004 | 05:29 PM
CF6873's Avatar
CF6873
You can use any 2 part adhesive made for SMC. Fiberglass-Evercoat has one available in quart cans that you mix together. 3M , Lord Fusor, SEM and many others come in a siamese tube that mixes in the applicator tip when dispensed with a special gun. Some body shop supply stores will loan you the gun when you buy the adhesive.
Old Dec 4, 2004 | 06:06 PM
beachbumskip
Cruising
beachbumskip
Cruising
To Body Glue
