Fuel Pump Replacement
Greeting from the C-3 contingent. There has probably been many threads on this topic and I apologize for not just doing a search but here goes. I have an 82 in tank pump/sender unit in my injected 80 C-3. With the new 420 ci SBC I am experiencing fuel starvation above 5,000 rpm. I had a 255 HP Walbro pump recommended to me and I have also heard they are very noisy.
1. Anyone willing to voice an opinion or option on eliminating the fuel starvation.
2. What is the recommended feed and return line size for a 537HP (at flywheel) engine?
Many thanks,
Ken
Many thanks,
Ken
I tuned a 57 chev some time ago with a 447 cid SBC with an old Accel DFI system on it. That engine had a fuel problem much like what one would call starvation. But his problem was that the fuel was being heated so much by the engine compartment that it was actually vapor locking. He had such a big pump in the tank that with every round trip of the return fuel it was picking up a little more engine compartment heat. The fancy stainless steel tank that was in the trunk of this car was so hot that if it was a hot tub I would hesitate to get in it. I replaced the pump with a bosch in tank pump, insulated the lines and he made some mods to the engine compartment to get more ventilation thought it and that cured his problem.
Then the other day I was tuning a friends 383 C4, it ran out of fuel at 3500 RPM. A new fuel filter temporaily cured that problem which reared its head again at 48000 RPM. Replacing the pump cured the problem all together. She revved to 6000+ with not a hint of any fuel issues. The AFR across board was well within my target of 12.5:1 beyond 4000 RPM.
Many thanks,
Ken
RACE ON!!!
