what cam to pick??????
Old Dec 25, 2004 | 06:58 PM
MITCH's Avatar
MITCH
Default what cam to pick??????
here are the spec's on my combo 422 ci motor, tpis mini ram ,afr 210 heads, vig 3000 stall conv,3.73 rear,30psi injectors,58mm t/body,forced air, tpis zz409 cam. i think i need more cam.
1.6 rockers.
need some idea's
thanks
mitch
speednut2@aol.com
Old Dec 25, 2004 | 08:07 PM
Zix's Avatar
Zix
1.6 rockers.
need some idea's
thanks
mitch
speednut2@aol.com
Do you need to pass emissions? Have you thought about going to a solid roller? How do you want the car to perform? Street driven only...any track time?
I do agree that I think you could use more cam. There is a grind going in my 383 that has exceptional results...it's big and not likely to pass emissions, the duration @.050 is 242/252, and the lift with 1.6RRs is in the .56x-.57x range, I don't have the card in front of me. There is also the GM847 cam that has been getting very good results as well, it has a little less duration at 234/242@.050 and little more lift at .574/.595 w/1.6RRs. I think either of those would be a nice choice!
Old Dec 25, 2004 | 08:28 PM
SHINOBI-X's Avatar
SHINOBI-X
what LSA are those cams.when i build a stroker i'd like to keep it at 114 becaue of good idle characteristics and vacuum.i need to pass smog aswell.are all you LT1/L98 guys using 112's?i would think it would take a little more tuning to get it right.thanx in advance.
Old Dec 25, 2004 | 10:53 PM
Zix's Avatar
Zix
The LSA if I remember right is 112. you can always get a vaccum pump to make up for any loss.
Old Dec 25, 2004 | 11:09 PM
LD85's Avatar
LD85
When I called AFR and spoke with them, they said I would need a 242/246 cam with at least .600 lift to get the most out of the 210-heads. Having driven in a TPIS 701 cam = 242/242 Solid roller, I would say they are right and I would go with at least the 701 cam.
Old Dec 26, 2004 | 03:11 PM
MITCH's Avatar
MITCH
my car ran 11.29 @124.87 with a super ram and the same combo car would idle like **** but run great. put the mini ram on and the car has a great idle but run like ****. emssion's are not a problem for me.the car will see some track time but most of it is going to be street driven. i know the cam is small for what i have. i need some help!!! id85 how is your car running do you still have the mini ram on your car.i have all the best **** in this car and i want a 10sec time slip.
thanks for any help guys.
mitch
speednut2@aol.com
Old Dec 26, 2004 | 03:24 PM
luvmy92's Avatar
luvmy92
I have a friend with a 383 using the AFR 190's, miniram, TPIS headers, etc, and he went with the ZZX cam (239/239). This car is a road racer only, but it put down 411 to the rear wheel. I't sounds bad as hell and runs as good as it sounds.
Mike
Old Dec 26, 2004 | 04:08 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Mitch.
I am going to be going larger with my cam, I ran this past year. Its a Lunati billet piece that is noted in my signiture. If you would like to work something out, I think it could work out for both us.
The cam idles great and purrs like a kitten on the street. It suprised me, and the reason I am going to go even bigger and into more unchartered waters. I am surprised at how these larger inch motors take to relatively large cams.
I am going to venture into the 27X duration world maybe even 280s
Old Dec 26, 2004 | 04:45 PM
LD85's Avatar
LD85
mitch
speednut2@aol.com
Hey Mitch, I am swapping to the Superram in a few weeks after it is fully ported, I dont want "more" cam which would be better for the Miniram.
And because I have a cast crank the Superram is better plus I think the 233/233 Hyd-roller will work fine with the Superam too.
I agreee with Jesse, the bigger cube engines wtih EFI really can handle more cam than one would expect, even the cam guys I have talked with are surprised at how much cam the EFI 's seem to handle.
Old Dec 28, 2004 | 01:01 AM
thetoy's Avatar
thetoy
Jesse how much lift are you thinking about with your new cam?
Old Dec 28, 2004 | 01:19 AM
tjwong's Avatar
tjwong
Shinobi, you won't be passing emissions with the GM 847 cam. Its LSA is set at 112. I squeaked a comp 306 cam by emissions in an F body a couple times with its 230/244 specs or something like that, it too is ground on a 112. I doubt I can squeak that GM 847 cam through emissions. Maybe it could be done if I used the Alky trick, but even then I think it would be tough.
Old Dec 28, 2004 | 02:41 AM
Zix's Avatar
Zix
Would it be possible to put on a set of 1.5 RR's jsut for the emissions? That would bring the duration a little closer to the CC306 and lower the lift a little as well.
Old Dec 28, 2004 | 07:33 PM
MITCH's Avatar
MITCH
what are the spec's on the cc306 does anybody know.
jesse i will keep it in mine.
mitch
Old Dec 28, 2004 | 08:24 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
I am limited to .650 with the current springs I have. So I was going to call UD harold and see what he thinks would work in the .640 lift range.
Mitch. Let me know ASAP./ I also have a set of practically brand new hi-tech roller lifters that I ran for a very short period of time. I keep forgetting I have them and should sell them.
Jesse
Old Dec 29, 2004 | 12:35 AM
red L98's Avatar
red L98
hey mitch ,
my brother is using the same cam jesse is using and its working great with the 210 AFR heads . this cam is very street friendly and i would go for it
To what cam to pick??????
