C4 Molding Help Needed
Old Dec 28, 2004 | 04:45 PM
C4BOB's Avatar
C4BOB
4th Gear
Default C4 Molding Help Needed
Need To Know Ware To Get C4 Door Molding Clips That Are Held On With 2 Screws Also Need DOUBLEl Sided Tape That Also Holdes The Molding Thanks C4bob
Old Dec 28, 2004 | 04:54 PM
C4BOB's Avatar
C4BOB
4th Gear
Old Dec 28, 2004 | 06:49 PM
SBNova's Avatar
SBNova
Those "clips" on each end of the door strips are not replaceable. They are part of the door trim assembly. Yes, they do unscrew from the plastic strip, but they arent available separately. The studs often beak off when you try to loosen the nut. You could weld in some stainless bolts, and use new stainless nuts too, then just screw them back on.
Old Dec 28, 2004 | 07:07 PM
mikey whipreck's Avatar
mikey whipreck
Go to a dealership parts counter, have them find the part # of the items you need then go to GMpartsdirect.com. They usually have everything a dealer will have access to...
Old Dec 28, 2004 | 08:42 PM
hgoodwiniii's Avatar
hgoodwiniii
Try Dino's Corvette Salvage www.corvettesalvage.com/index.html
Old Dec 28, 2004 | 08:45 PM
hgoodwiniii
Default C4 Molding
Try Dino's Corvette Salvage @ www.corvettesalvage.com/index.html
Old Dec 29, 2004 | 11:38 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Usually the stud will spin in the little flat piece its attached to before it will break off. If this is the case, here is what I did on my 85. I took the two screws out and cleaned it up good the scuffed the backside with sandpaper then put a bit of J-B Weld right on the back of the stud and the flat piece. Let it stand 24 hours and it's better than new. I have no idea about the adhesive strips but I'm going to check at NAPA because I need them too.
To C4 Molding Help Needed
