water pump gasket question
Old Dec 29, 2004 | 12:00 PM
redbullapril23's Avatar
redbullapril23
Default water pump gasket question
ok I bought new gaskets for my water pump
1996 auto lt1
and i got the old sealant off and put new sealant on the water pump and put the gaskets on and pressed them down with my weight. unfortunately i got called int work and never reinstlled the water pump.
will the gaskets be ok?
they are stuck firmly to the pump.
and its been about 3 weeks.
thanks alot your friend
Sean
Old Dec 29, 2004 | 12:07 PM
Strick's Avatar
Strick
What kind of sealant did you use? If it were Permatex Aviation form-a-gasket, I'd say okay. As the permatex doesn't really dry hard. Just see if you can dent it with your fingernail, if not get a new gasket. The more I think about it, start all over with new gaskets and clean surfaces.
Old Dec 29, 2004 | 03:08 PM
redbullapril23
got ya thanks alot your friend
Sean Blanton
email me for all your ceramic coating, powder coating and deep cryogenic processing needs
slimshaby@mindspring.com
Old Dec 29, 2004 | 04:03 PM
Strick's Avatar
Strick
Sean Blanton
I have you in my corvette file.
Old Dec 29, 2004 | 04:20 PM
redbullapril23
sounds great!
your friend
Sean
right now I'm doing headers for $188.
that includes coating inside and out, 3 yr warranty, and limited life time rust warranty!!!!
To water pump gasket question
