Automatic shifter..
Old Jan 8, 2005 | 09:17 AM
Bob86ZZ4's Avatar
Bob86ZZ4
I put the B&M Megashifter in that they make for console mounting in the 82-93 (or something like that) F-body. Had to do some work but I'm very unskilled so if I could do it anybody can. The cheap rubber boot doesn't reach down to the console top so I need to have a nice leather one made but havn't gotten around to that yet. Too busy driving. I did my shifter because I put in a manual valve body th400 with a Gear Vendors overdrive. This is the ONLY way to fly!
Old Jan 8, 2005 | 11:32 AM
eptaylor's Avatar
eptaylor
Default shifter
I finally found one pic of my megashifter installed under stock cover. Can I e-mail to someone and they can put on the forum?
Old Jan 8, 2005 | 01:54 PM
bigdreams65's Avatar
bigdreams65
Awesome job.. This is exactley what I plan on doing sometime soon. I have allot of other things I'm doing now to the engine compartment so the shifter will wait till spring/summer. Thaks for the pics. When I do get mine done I will post pics if I can figure out how.
Old Jan 8, 2005 | 02:13 PM
SEEYAAA
Guest
Posts: n/a
I have a hurst quarterstick in mine, it was a simple install using the brackets included with the shifter and only had to drill 2 holes, was able to use 2 factory ones. fits under the console plate and i only had to notch it slightly to be able to get 1st gear. it can prolly be done without notching by just moving the shifter forward a bit.
