Vortec Heads and Cam
Old Jan 4, 2005 | 06:17 PM
Carl Johansson's Avatar
Carl Johansson
Default Vortec Heads and Cam
Hey guys,
I have a buddy who is looking to unload a set of Vortec heads and a cam.
the heads have 194/150 valves
Fits any small block - haven't been drilled or tapped
Suposedly the heads make 50 extra HP and 50 ft lbs of torque
The cam is Isky .580 intake .54 exhaust Hydrolic roller with lifters
So I need to know:
Are these something that would be a good application for the vette? I assume that these heads are the same as the ZZ$ heads - but cast instead of aluminum.
Also he has a TH 350 with a stage 3 shift kit and manual valve body - is this a bolt in - or would it require modifications?
Carl Johansson
Carl Johansson
Old Jan 4, 2005 | 08:05 PM
cv67's Avatar
cv67
St. Jude Donor '05
I believe you need the appropriate intake for the heads. Bolt angles are different. Vortec cam?! Need more specs. That's an awful lot of lift for that head.
Old Jan 4, 2005 | 09:58 PM
TIMSPEED's Avatar
TIMSPEED
Originally Posted by Carl Johansson
Are these something that would be a good application for the vette? I assume that these heads are the same as the ZZ$ heads - but cast instead of aluminum. Also he has a TH 350 with a stage 3 shift kit and manual valve body - is this a bolt in - or would it require modifications?
I'm going with the Vortec Heads, but with the Vortec heads, you HAVE to have the Scoggin-Dickey Vortec TPI baseplate. Also, those heads, in stock form, will only handle about .450 lift, but if you swap the springs to Comp BeeHive Springs, and get them machined to work, they'll accept up to I BELIEVE .600 lift. The Vortec Heads are nothing like the ZZ4 heads, the ZZ4 heads are stock 88-91 Corvette Heads.
On the Th350, I do believe it's a direct bolt-in, but you'll have to change out the C-Beam and a few other things, don't really know that much on the conversion.
Old Jan 4, 2005 | 10:59 PM
gbody5's Avatar
gbody5
Yep that kind of lift with stock Vortec springs, not good!
Old Jan 4, 2005 | 11:16 PM
mean8t's Avatar
mean8t
I have the Vortec heads on my engine now. They are great heads for the money, but that cam is not the cam you want. The Vortec heads peak out at 239 cfm at .550" and taper off sharpley after that, also they will perform much better with a dual pattern cam that has a lot more exh duration and lift, since that cam has the exact opposite it would basicly suck. Something like the XE276HR or the ZZ4 cam with 1.6 RR. Either would be an excellent combo, I am running the XE268H with 1.6RR and that brings the lift up to the neighbor hood of the XE276HR. Untuned it is a screamer!!!!!
Old Jan 4, 2005 | 11:20 PM
tjwong's Avatar
tjwong
Also did you guys know the GM Performance parts also has a new Vortec head offering. There are two versions, with LT4 hollow stem valves. One has 175cc intake runners, and 65cc exhaust runners. The larger of the two has 206cc intake runners and 76cc exhaust runners. These heads should offer exceptional flow for the money. At about $1000 per assembled set these are a pretty good bargain.
Old Jan 4, 2005 | 11:28 PM
ICANTDR55's Avatar
ICANTDR55
How much for the set up?
Old Jan 5, 2005 | 12:42 AM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
Timspeed and mean8t are right. You will need to buy the Scoggin Dickey intake base... but the rest of the stock intake bolts right up. The Vortec heads are a great head for a stock replacement mod... in other words if your entire motor is stock and you want bolt on hp and you don't plan on going insane with it... vortec is a gr8 head.
I don't think those heads will work with that cam as stated above... but if I'm not mistaken, there is an aluminum version of the Vortec that will handle that cam and more... but I could be wrong. I had to trash my SPDC catalog before my wife divorced me for spending our vacation savings on more car parts.
Old Jan 5, 2005 | 01:10 AM
mean8t's Avatar
mean8t
I just looked at those heads and they look great, but aren't they in the same price range of AL fast burn heads?
Old Jan 5, 2005 | 03:41 AM
cv67's Avatar
cv67
St. Jude Donor '05
I think the aluminum fast burn head is 210 cc's if I'm not mistaken. For the money, Vortec heads make excellent torque- About 40lbs more than the L98 113's. You'll definitely feel that. $500 well spent
Old Jan 5, 2005 | 11:21 AM
tjwong's Avatar
tjwong
The Fast Burn heads are about $200 more per set. And they have larger runner volumes. So for something that requires a lot of low and mid range grunt the new Vortec heads should fill that need. Not to mention that the Vortec head uses basically the same "fast burn" chamber design as its big brother aluminium Fast Burn version does. If I were to build a torqy truck motor these heads would be my choice. In fact I am building a 406 for my kid brothers 65 chevy pick up. He couldn't afford the new versions but we are using the standard Vortec heads on this engine with some minor mods to them
Old Jan 5, 2005 | 12:22 PM
mean8t's Avatar
mean8t
I put my motor together about a year ago and have only driven it for about 6 months and it is a great motor. It still is untuned and running lean up top so we will see.
Old Jan 5, 2005 | 12:27 PM
mean8t's Avatar
mean8t
In fact with the stock vortec heads, the scoggin-dickey base, and 1 3/4" open headers they made 300 chp on an otherwise stock TPI with an untuned 87 computer. They made pretty good torque but they said that they could have made more with 1 5/8" and a good dual exhaust. I think it was an article in Chevy High Performance as I remember.
Old Jan 5, 2005 | 06:48 PM
cv67's Avatar
cv67
St. Jude Donor '05
That's where I got my info!
To Vortec Heads and Cam
