An elementary question...
Old Jan 14, 2005 | 10:28 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Default An elementary question...
Okay, at the risk of sounding like a complete novice (cause I am...):
Scenario: changing out brake MC. Would you attack the brake line fittings with PB blaster before you even start as a preliminary caution? Will PB blaster soak into the brake lines and hurt anything? I have done several searches and it sounds like these things are really easy to round off, even with flare wrenches. I REALLY don't wanna go there...
TIA
-Ed
Old Jan 14, 2005 | 11:05 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
With my OEM rear calipers it took several applications of PB Blaster, a small section of pipe on the handle of my 1/4" socket and several taps with a small hammer to break the rear bleeders free.
The brake lines at the MC didn't require any persuading as there was no trace of corrosion.
Old Jan 15, 2005 | 11:58 PM
smacko's Avatar
smacko
Dunno what 'PB Blaster' is but I assume brake cleaner spray?
I'd use penetrating spray (WD40, INOX, RP7 - insert whatever brand you have over there) and let it work for a day or so if possible; it shouldn't get into lines. Use the CORRECT size flare wrench and nothing else and you should have no probs. DO NOT EVER be tempted to use ANY other type of wrench or vice grip pliers; they WILL destroy your nuts (And won't help with brake line nuts either); been there recently; OH BOY!!!
Any residual garbage in lines should get flushed out anyway when you FLUSH (Not just bleed) brakes after you've installed the MC.
****Read also my recent posting on how to adjust carefully, the pushrod from brake pedal to MC; incorrect adjustment can destroy pads & rotors REAL quick (In my case in about 20 miles!)
Old Jan 16, 2005 | 12:10 AM
ALLT4's Avatar
ALLT4
PB Blaster is by far the best penetrate I've ever used, PERIOD!
Forget that WD40 or anything else, waste of money for breaking bolts loose.
Old Jan 16, 2005 | 12:37 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Yes, go ahead and pre-soak them w/ PB. It won't hurt anything and can't get into the system as long as everything's tight. Once you get them cracked loose, wipe them off and then spray it with brake clean and wipe it off again. It'll be fine.
Old Jan 16, 2005 | 03:14 PM
eschoendorff
St. Jude Donor '08
That's what I wanted to hear. Thanks!!!!
I just bought the Craftsman "professional" line wrenches (no Snap On because I am a teacher and don't have any $$$ ). They sure do look pretty... hopefully they'll do the trick.
Smacko:
As far as putting vice-grips or pliers on my nuts... my wife has threatened me before but damn! That's just sick!!!
I read your post on the pushrod adjustment. I am going to leave it alone until I know there is a problem. I have your post book marked in case I need to go there. thanks!!!
To An elementary question...
