Tech Tip
Old Jan 15, 2005 | 08:29 PM
ALLT4's Avatar
ALLT4
Default Tech Tip
Sometimes you find yourself looking for TDC by yourself, to time your dist. whatever. Better than having a buddy use his finger or buying a real whistler I came up with one of those "it's so simple it's stupid" moments.
Grind it, wire wheel the threads and you've got your own home made whistler. Someone else may have thought of this but I've never seen it anywhere.
Old Jan 15, 2005 | 08:33 PM
BRICHC4's Avatar
BRICHC4
what's going on?
Old Jan 15, 2005 | 09:38 PM
MikeC4's Avatar
MikeC4
Originally Posted by BRICHC4
what's going on?
OK....what does this plug do? whistle when the #1 is at full compression stroke or what???
Old Jan 15, 2005 | 09:44 PM
smacko's Avatar
smacko
interesting...
Old Jan 15, 2005 | 10:02 PM
joe3906's Avatar
joe3906
Old Jan 15, 2005 | 10:03 PM
ALLT4's Avatar
ALLT4
Yeah, sorry, I thought it was fairly obvious. When ever you hear the PFFFFFTTT you know it's coming up to compression then just line up the marks on the balancer whatever, install distributor.
Old Jan 15, 2005 | 10:07 PM
bogus's Avatar
bogus
Simply brilliant.
I will have to do that.
Old Jan 15, 2005 | 10:08 PM
netnarc3's Avatar
netnarc3
OK, so it whistles when you have the piston at TDC under compression so I take it that you have to be under the hood adjusting the distributor manually and using the whistle as a guide to tell you where the engine firing order is at? You're answer came up right after I posed my question. Now I get what you're saying. That would be a great idea when installing a distributor.
MikeC4's Avatar
MikeC4
ahhhh, OK, the same sound my dog makes!! Thanks
Old Jan 15, 2005 | 10:18 PM
Curveit's Avatar
Curveit
Slick idea there!!!
Old Jan 15, 2005 | 10:23 PM
ClarenceT's Avatar
ClarenceT
That's pretty cool.. I used my comp guage before.
Old Jan 15, 2005 | 10:27 PM
1989redvette's Avatar
1989redvette
could just stuff a paper towel in the hole.. #1 cylinder is right there on the drivers side and with that clam shell hood ya can definatly see..
Old Jan 15, 2005 | 11:03 PM
ALLT4's Avatar
ALLT4
Yup, whatever works for ya.
However there's no mistaking the ridiculously loud hiss that plug makes.
Old Jan 15, 2005 | 11:40 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
GREAT TIP.
Thanks for passing it along.
Old Jan 16, 2005 | 01:37 AM
tempest's Avatar
tempest
(smack on forehead) now why didn't *I* think of that????
pretty cool.
Old Jan 16, 2005 | 02:37 AM
olman's Avatar
olman
pretty cool.
Old Jan 16, 2005 | 03:33 AM
pablocruise's Avatar
pablocruise
Looks like a funny prank I can use for april fool's or something.
Thanx
To Tech Tip
Old Jan 16, 2005 | 05:37 AM
myvettesblue's Avatar
myvettesblue
St. Jude Donor '05
make sure you put a patent on that that is a great idea all those years i thought you just stuck a screwdriver in the hole and when it bent in half that was tdc just kidding
Old Jan 16, 2005 | 01:53 PM
eptaylor's Avatar
eptaylor
Default good idea
Now that's a good idea. Your're right about so simple but how many others thought of it? I will certainly do this. Thanks
Old Jan 16, 2005 | 03:10 PM
96dblblack's Avatar
96dblblack
Good deal. Yes it was simple, but I never thought of it. Nice work
