*w.t.f*
Old Jan 16, 2005 | 01:28 AM
Perfusion's Avatar
Perfusion
Default *w.t.f*
Here's the deal: Tonight, I go out to my car - 96 LT4 w/ 49xxx miles - to pick up some takeout. Outside temp is a moderate mid-40s degrees. I get in, put the key in the ignition, and turn...release - no start. Turn again, hold until I think it should be good to go - no start. Turn and hold for a third time - crank-crank-crank-crank-crank - by now I'm waiting for the sun to come up, and she starts...reluctantly. I pump the gas pedal...rur-rur-rur...she *Finally* kicks into what I would call "normal" idle.
What the *hell* was going on tonight? This is the first time my car has EVER done anything like this, she was driven yesterday, and I don't think it's the coldest temps she's ever seen... What caused such a "hard" start??? Whatever it is, I want to fix it. I will fix it. NOW. Somebody gimme a clue, though, as this one caught me out of the blue...
TIA.
Old Jan 16, 2005 | 01:38 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I believe th west coast has had excessive moisture recently; moisture in the ignition or condensation in the fuel might cause such symptom, expecially if fuel level is low.
You might try a can of dry gas in the tank.
Old Jan 16, 2005 | 01:45 AM
bogus's Avatar
bogus
I agree... sounds like moisture in the tank.
add a bottle of dry gas, fill'r up, and all should be ok.
Old Jan 16, 2005 | 01:55 AM
Perfusion's Avatar
Perfusion
Wierd... I just tanked 'er up day before yesterday...and only 14 miles since then.
Old Jan 16, 2005 | 01:57 AM
bogus's Avatar
bogus
odd... check your filter. They can go south if too much moisture goes through them.
Old Jan 16, 2005 | 03:43 AM
tm1995c4-LT1's Avatar
tm1995c4-LT1
Pull each individual plug wire (at the plug) and spray WD-40 in it. Worked for me once when mine did the same thing.
Old Jan 16, 2005 | 08:39 AM
Nathan Plemons's Avatar
Nathan Plemons
It could be that your fuel rail isn't holding pressure like it's supposed to.
It's simple enough to check, wouldn't hurt.
Old Jan 16, 2005 | 09:26 AM
Strick's Avatar
Strick
You guys have had more rain than Noah had. This can raise hell with gas stations. I'd suspect gas with a little water mixed in. Dry gas to the rescue. I hope your filter didn't get too much in there.
Old Jan 16, 2005 | 11:39 AM
mikey whipreck's Avatar
mikey whipreck
That's probably your problem then...
You paid $2 a gallon for water... with maybe a little gas mixed in...
Old Jan 16, 2005 | 11:41 AM
95VETTEINMEMPHIS's Avatar
95VETTEINMEMPHIS
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-11-'12-'13
Heck mine did that a couple of weeks ago and turned out there was alot of corrosion built up on my battery cables cleaned them and good as new. Just a thought.
Old Jan 16, 2005 | 12:51 PM
Caboboy's Avatar
Caboboy
Are you going over to jhong's house this afternoon? If so, bring a fuel filter and we can change it while we're doing his hood
Old Jan 16, 2005 | 03:05 PM
Perfusion's Avatar
Perfusion
I'm not gonna be able to go to Jerome's afterall, but it sounds like a bottle of dry gas is in my future...
To *w.t.f*
