Fuel System
Old Jan 16, 2005 | 02:55 PM
RUDY S's Avatar
RUDY S
Default Fuel System
GOING TO CARB SET UP. WHAT NEEDS TO BE DONE?
Old Jan 16, 2005 | 03:23 PM
bogus's Avatar
bogus
First, turn off the caps lock....
I have to ask, why?
As for what needs to be done? Computer mods to turn off the injection... a lower pressure fuel pump. intake, carb, air filter.
I am just not a fan of the carb... its old school tech. yuck.
Old Jan 16, 2005 | 04:34 PM
CFI-EFI's Avatar
CFI-EFI
Originally Posted by bogus
First, turn off the caps lock.....
Second, go have your head examined.
I have to ask, why?
Don't forget an old style mechanical distributor and a means to engage the TCC if you have an automatic.
RACE ON!!!
Old Jan 16, 2005 | 05:10 PM
MikeC4's Avatar
MikeC4
bogus, you crack me up!!!!!!!!!
IMHO, if you a Carb, buy a C3...why go to all the trouble?
Old Jan 16, 2005 | 07:39 PM
randy814u's Avatar
randy814u
There are a number of carbed c4 owners on here. So if you run into any problems or questions, you can do a search for the topic, and send them a pm, or email. I am sure they would be glad to help, and not try to make you feel bad for what you want to do to Your car. I went carbed, and I would never go back. Randy
Old Jan 16, 2005 | 08:56 PM
RUDY S's Avatar
RUDY S
THANKS RANDY
Old Jan 16, 2005 | 09:35 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
caps lock Caps Lock CAPS LOCK
Old Jan 16, 2005 | 10:50 PM
bogus's Avatar
bogus
online, all caps means yelling. I can't tell you the number of times I have encountered posts in all caps, with little or no punctuation.
A friendly reminder at this point is all it takes to break one of the habit.
Oh, thirdly, chill.
Old Jan 16, 2005 | 11:09 PM
FD2BLK's Avatar
FD2BLK
I don't know what year car we are dealing with so I will just tell you what it took on my 84
1. you will need a Fuel Preasure Regulator and a T fitting for the fuel lines one end of the T fitting goes to the suply line the other to the carb and the other to the FPR to the return line
2. Intake (The lower the better)
3. Carb
4. A TC lock up kit and TV cable kit if 700R
5. A pre CPU distributor (75-77 corvette HEI works perfect)
Thats about all I can think of at the moment.
Old Jan 17, 2005 | 01:08 PM
crheinish's Avatar
crheinish
Get a GM Performance parts catalog. Everything you need is in there.
To Fuel System
