volts
Old Jan 17, 2005 | 06:43 AM
dm1948's Avatar
dm1948
Default volts
have a 89 coupe what reading should i get on my voltmeter
Old Jan 17, 2005 | 07:23 AM
1stC3Vette's Avatar
1stC3Vette
I have the same year. Mine displays anywhere from 13.4 to 14.0 depending on the situation. Meaning, if it is just started, then the voltage is a little lower, as I drive, it starts going up. 14.0 is the peak I have seen.
Good luck,
Dino
Old Jan 17, 2005 | 08:19 AM
dm1948's Avatar
dm1948
thanks for the info,looks like i'm ok
Old Jan 17, 2005 | 08:33 AM
REW89's Avatar
REW89
In the winter mine reads 13.7-14.0
As car warms up the reading drops. The number that appears to be the most common is 13.7-13.6.
The A/C really saps voltage and when combined with summer heat down here can get the reading down to the low 13's. High 12's occassionally show up while waiting at stop lights with everything running.
MTCW.
Old Jan 17, 2005 | 09:53 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
13.5 +/-.5volts, when the engine is running but without a load, is considered acceptable.
Larry
code5coupe
To volts
