ZF Fluid
[QUOTE=Cdn ZR1 Mike;1561489685]
Hey Tom, apparently this stuff comes straight from Germany and it is only available through BMW....as I understand anyway. I have the OEM stuff in the trans now but will change the fluid again shortly with the Castrol and see if I notice any difference.
Want me to buy a case for you Canucks?
Thanks for the offer Jeff but I'm done for a while now anyway. I'll hopefully have that parts order for you shortly.
Mike, Let me know if you notice a difference...I have to change mine soon and seems there is alot to choose from. I won't use Redline, I remember about 8-10 years ago reading about some of the Team ZR-1 guys burning up ZFs with Redline fluid.
FWIW, I just bought some recently and the Castrol TWS was $13.25 a quart from the local BMW place. When I'd bought it a year ago it was under $9 a quart. Thank God I don't have an engine that requires it!
Tom....I'll keep you posted.
Premium Supporting Vendor
AMSOIL Synthetic Synchromesh Transmission Fluid (MTF)
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
Received 3,043 Likes
St. Jude Donor '05
Never tried it but I have never once heard a negative thing about any type of Amsoil.
Im guessing they must all be pretty close.
Also, (in case you don't know this yet) make sure you take out the fill plug before you take out the drain plug. Sitting there with all the fluid drained is the wrong time to find out the fill plug is stuck.
Merry Christmas
Actually, it doesn't have to be level when you fill it. I find it easier to mess around with it while the side is raised a bit. I fill it up, leave the drain pan under it, lower the car and let the excess fluid drain out, then raise it up again to put in the plug and torque it properly. It's just a lot easier than trying to do that with the car on the ground. Especially trying to turn a wrench on the fill plug, the handle hits the ground all the time.
I don't think I'd try that with ramps though.
#33
I have Mobil 1 15w50 extended life in mine right now. I do have something going on with my 2nd gear syncro though, when running the car hard the trans will scratch while going into 2nd. Could this have been caused because of improper lube? I had figured it was just due to two many perma grin runs.
#38
My first ZF burned up...
Bill Boudreau (ZFdoc) sent me some data showing the viscosity of the ZF transmission oil and the amount of particulates suspended therein for various miles. I wish I had the info he gave me to show you, but in essence, what I took from the article/test was 15,000 to no more than 20,000 miles (as I recall) for "normal" Corvette highway driving, or more often if you're doing racing.
I had put 20k miles on the transmission that was in the car from the time I bought it (used) when suddenly it caused the car to act as tho I had mashed on the brakes - eventually locking up and sliding to a stop. But, I have no idea how many miles the oil had on it prior to my buying the car. However, after talking to Bill B, I suspected the oil level had been low and I was unaware.
But, when I drained the broken transmission, to my surprise it was not low on oil as I had expected, but it did have a greenish-grey/black appearance with a significant amount of particulate matter in it (no surprise there).
Upon taking delivery of my new ZF transmission, here is what Bill B said:
>>>The transmission will come filled with Castrol TWS 10W-60 full-synthetic oil after it has been balanced and blueprinted. 15K mile interval between changes are advised. Your build sheet will specify BMW part number and quantity required for transmission oil change.<<<
I'm no expert, but Bill is. So, I'm going with his suggestion before spring so I have a starting point on my "new" Z.
I guess my point is, "We're not in Kansas anymore, ToTo..." And, the ZF is not the same animal as the ol' M21 or M22 GM 4-speed either!
FWIW,
P.
FWIW,
P.
#40
I use the expensive BMW oil too (it is speced for some M series engines). I found the price varies greatly from dealer to dealer. I recall paying about $10 per qt./liter.
