A&A Corvette Performance:Forced Induction Q&A thread
Old Apr 20, 2005 | 12:07 PM
DickieC.99's Avatar
DickieC.99
Originally Posted by Andy@AandACorvette
...If you want any other kind of valve like a Tial, Greddy or whatever, just send me the mounting flange and I'll weld it on the tube and assemble the valve on the tube at no charge. I just did a Tial the other day. It sounded mean!...
That sounds awesome Andy! I have a couple friends that have Tials. I think they sound badazz. I know you can order it with either a steel or aluminum flange. Which one should I get?
Old Apr 20, 2005 | 06:15 PM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
Get aluminum. Send it to me and I'll weld it on the tube for you.
Old Apr 26, 2005 | 06:42 PM
imxz28's Avatar
imxz28
Andy,
Does the kit come with a pin for the hub?
I did not see the instructions for that.
Old Apr 27, 2005 | 01:54 PM
Andy@A&ACorvette
Yes. The pin kit is included.
We also sell the pin kit separately ( $50) for those that need one.
Old May 2, 2005 | 03:57 PM
denscor's Avatar
denscor
Hello I'm getting one of your brackets but I do not know which one to get the 6 rib or the 8 rib? I'm only planning on making 10 psi of boost on a stock bottom end for now! But in the future I would like to have more boost! And a forged bottom end! So what are you suggestions? How hard is it to change a 6 rib to a 8 rib or would it be better to do it now? What is the cost difference? What is max boost with a 6 rib before it starts slipping?
Old May 2, 2005 | 05:29 PM
Andy@A&ACorvette
denscor: Just goi with the 6 rib. My newest bracket will suppoort 10# on a six rib, no problem. Much more than that would be better off with an 8 rib.
When you decide to upgrade you'll just have to buy the 8 rib pulley kit. The full setup is a little over $900. I'll ugrade the bracket itself at no charge when you do.
Thanks.
__________________
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
ANDY GREEN- OWNER/ CEO -A&A CORVETTE / A&A SUPERCHARGERS
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
Old May 2, 2005 | 10:36 PM
denscor's Avatar
denscor
Thanks a Million Andy!!!
Old May 3, 2005 | 11:35 PM
Andy@A&ACorvette
Any time!
Old May 6, 2005 | 03:19 PM
AVB's Avatar
AVB
Hey Andy,
Last time we spoke I mentioned getting my car down there for you to tune on your NEW dyno.. What I forgot to mention is that I'm currently using EFIlive to tweak here and there and will most likely be running in SD w/ a 2bar by the time I get to you. I'd like to be able to retain programming under EFI and am wondering if that's what you would/could use.
~Arnel
Old May 6, 2005 | 10:06 PM
Watch22's Avatar
Watch22
Andy,
I'm getting ready to order your P1SC kit and have a few questions.
1. What else do I need besides the base kit?
2. I don't want to blow the engine quite yet, what would be a safe boot 5psi? and what pulley size? 4.50? I also have headers, which I could put the stock exhaust back on if necessary for safe power levels.
Old May 7, 2005 | 08:22 AM
jbkblown's Avatar
jbkblown
Default Belt size
Hi Andy, I'm going to be changing over to your new bracket system and was wondering if the belt size is going to be the same? Currently I'm running with the MMS bracket Assembly.
Old May 7, 2005 | 11:23 AM
Andy@A&ACorvette
magdc5: I use LS1 Edit for tuning. Haven't messed with the 2 bar at all.
Watch22: All you'll need is a Kenne Bell Boost A Pump or an in tank pump to finish the installation. I can flash your PCM with a safe tune for $100.
I use a 4.10 pulley on the LS1 and 4.25 on the LS6. With a consevative tune, that will be nice and safe. Leave the headesr on, that's free horsepower.
jbkblown: No my belt will be shorter. I'll get you the correct belt size, depending on your pulley size.
Old May 7, 2005 | 01:59 PM
  #33
jbkblown's Avatar
jbkblown
Default Belt size
Andy, I have a 3.85 pulley. When you send the bracket, include a belt to my bill. Thanks Andy.
Old May 9, 2005 | 12:00 AM
  #34
Bigben's Avatar
Bigben
Andy, how much is one of your Stage 2 Forged 348's installed? Also, curious about what it costs to ship one?
Old May 9, 2005 | 07:22 PM
  #35
Andy@A&ACorvette
The short block is $3500 including any cam you choose, double roller timing chain, oil pump, forged pistons and rods. I have them on the shelf already built.
Call me for installation prices. The install would require a complete removal and reinstallation of your Vortech supercharger system as well as an engine R&R. What about heads? Are you upgrading or leaving them stock? A lot of variables.
Old May 10, 2005 | 11:10 PM
  #36
Doczo6's Avatar
Doczo6
Hey Andy, I got the fed # for the blow off valve, Thanks I sent you a pm also
Old May 13, 2005 | 01:20 PM
  #37
bayarea's Avatar
bayarea
Andy what do you charge to forge my motor and install the d1sc procharger? if you could pm me the price that would be cool
To A&A Corvette Performance:Forced Induction Q&A thread
Old May 13, 2005 | 06:55 PM
  #38
Andy@A&ACorvette
I have forged short blocks in stock, ready to go. I'll get with you on a complete package price.
Thanks, ANDY
Old May 13, 2005 | 10:37 PM
  #39
petercln's Avatar
petercln
Hey Andy
could you tell us how much rwhp a 04 zo6 and take fi. What i mean is where is the cut off point say for the stock fuel system with a boost a pump. The stock pistions , clutch , rear , trans etc. I have plans to up grade my clutch and rear when i go fi. The car will be used for drag racing with dr or dot slick. thanks Peter
Old May 14, 2005 | 10:22 AM
  #40
Andy@A&ACorvette
The average Z06 will make about 560 RWHP with just my blower system and a set of headers. The fuel system is upgraded with just a Kenne Bell Boost A Pump.
That's about the limit on the fuel system without a major overhaul.
While I've seen the stock pistons take more than this, I think this is also just about on the edge.
At this level, you'll want hardened output shafts and an upgraded clutch for track use. For a street application, I'd leave the clutch and rear alone until you actually need them. The tires will give up before the clutch.
Hope this helps.
