St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
I'm running a 234/240 598/608 114LSA and plan on SC (KB twin screw) with that cam. Some tuners have told me it's "too big", others have said it has "too much overlap" and one has said "it's larger than necessary, but it will be fine"
I'll report back on my results with the KB TS once it finally becomes available. Right now I'm enjoying the wild lope and insane wail from 4000rpm to redline (7k)
Holy smokes!!! Are you gonna put this on your stock pistons or are you gonna forge first. I'd love to see what that combo would put down with a forged 6.6litre.
I have A @ A's Blower Cam it's a 224/228 .581 .588 with a 115 centerline. I did a cam only before I did the ECS D1 kit and I gained over 50 RWHP from this cam alone. Kinda stealthy but sounds mean. I have no cats with Corsa Indy's and long tubes...... IDLE
This is the cam I'm currently using and YES it rocks!!!
224/228 .581 .588 115LA.
It pulls hard, sounds mean as hell, and is very streetable!!!
All you guys running these blower cams, how many of you had the blower first, then decided on the cam? I'm running a I/C Maggie, done by Lingenfelter, and they said if I install a cam, NO RETUNE is necessary Of course they would know, but why no tune? Is it cause is just a mechanical change?
If thats the case, which cam would be best, Lingenfelter or A&A. Or are they the same?
EG
I have a
Spec of cam
INT EXH
ADV DUR: 283 291
DUR @ .05: 234 242
VALVE LIFT: .598 .610
114LSA
Don't know if I want to use it on a twin turbo car, with that cam just in my heads and cam car it pulled dam hard from 4K-7K
exlr8shn. How much are you putting to the tires? I was looking at the F7 for my 02 Z06. How lopey is it? What does it idle at? How is the drivability? I have the A@A P1sc and am getting Supermaxx headers. Thanks.
i just order 224/228 cam . with forged bottom end . i cant wait ...
How about a cam spec for me? Daily Driver, but want a mild lope
2000 C5 Auto
3000 stall
408ci forged
Ported polished LS6 Heads around 290+cfm
LS6 Intake
ATI 10psi
2000 C5 Auto
3000 stall
408ci forged
LS6 Intake
ATI 10psi
408ci .. i think there is no problem to biger cam . its depend on what are you lookn' for ..
The spec's are 232/240 at .050 .595/.608 lift with a 115 lope separation. This cam works very well for forced induction applications, and yet it will still give the engine a lopey idle.
I am in the middle of a 408 forged with 320/260 cfm on my heads. I just sent my P1 off to ATI for D1 exchange and a 4.1 pulley. I have the A&A bracket, LS6 intake, 60 lb injectors, and TPIS long Tubes.
I am looking for between 10psi and 12psi on my D1 unit.
Current comp ratio is 8.71:1.
Is the 238/244/115lsa with .605/.612 lift a bit much? I drive the car every few days for 25 to 50 miles at a time looking for fun and I would take a 300 mile trip every few months.
MTI suggested a smaller cam like a 228/232/115lsa with .588/.575
What kind of stall should I be running to match each cam as well?
1st guess is a 3000 with the 228/232
and a 3400 with the 238/244
LS2 402 AFR 225's 9.5:1 comp with procharger D1SC 8 rib 4" pulley @ 15psi/6700rpm.The cam I'm using is a comp cams 228/232 114 lsa 588/595 I purchased it from A&A Corvettes.
