The spec's are 232/240 at .050 .595/.608 lift with a 115 lope separation. This cam works very well for forced induction applications, and yet it will still give the engine a lopey idle.
do you have a insite on were to buy???? and what kind of power gains do you get from it
I have A @ A's Blower Cam it's a 224/228 .581 .588 with a 115 centerline. I did a cam only before I did the ECS D1 kit and I gained over 50 RWHP from this cam alone. Kinda stealthy but sounds mean. I have no cats with Corsa Indy's and long tubes...... IDLE
Very steep, I just had mine done for $1400, 224/228 .581 .588, I have an A&A p1 setup, I did kooks longtubes minus cats at same and gained 100 rwhp, this cam pulls all the way to redline, big difference, nice lope if you keep idle around 700 rpm. Good luck.
I run the same cam except on a 114 lsa. Awesome all around cam and really makes the power with a blower.
I talked to andy he said he wouldnt go over a stock z06 cam on my stck c5 bottom end
Lots of miles on your motor? I was planning on getting a blower cam instead of LT's when I get my SC installed, but this makes me think I should reconsider and just look for some Kooks LT or LG.
ive got 76000 miles on it everyday driver commute about 200 miles a day to work I got it in december with 43000 miles on it is that high ot on it mileage? I had 100 shot on it the tranny went out so its getting a built 1 right now I just ordered the blower from andy. thats pretty much my life story
