dyno sheet inside
Old Oct 4, 2005 | 04:44 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
Originally Posted by SS930
Nick, you really need to get on a dyno that can place a load on your engine, otherwise your turbos will not spool properly (as you are seeing). With the TE44's, those babies should hit REALLY low!
yeah,,,, they certainly hit full boost wayyyy before 4k on the street. actually when the e. cutouts are closed it hits around there. i'd say that it hits max approx. 3200 rpm(best guess) actually ill check my data loggger on my 1/4 run last night.
Old Oct 4, 2005 | 05:13 PM
algZO6's Avatar
algZO6
How in the hell do you change the plugs?
Old Oct 4, 2005 | 05:39 PM
NICK YOSKIN
St. Jude Donor '08
easy!
the two rear plugs on both sides are a snap. the ones in front can be taken out from the top or the bottom. i was replacing the tranny in my car so x pipe was off and its easy to get to them from underneath w/x pipe off.
Old Oct 5, 2005 | 12:57 AM
Shinobi'sZ's Avatar
Shinobi'sZ
Originally Posted by NICK YOSKIN
easy!
I actually found a new way that simplified it some more.
#1&3 can be reached using a long extension 3/8" drive, and a universal (I put electrical tape around it to stiffen it up) plug sockect. You can slide it in right over the top of the shock tower on the driver's side.
